2000 blazer heater core removal
hey all.
well i just got my power steering fixed and i do beleive my heater core went out.
symptoms: when heat is on a nasty smell which i do beleive is the dex cool coolants and there's smoke coming out of the vents. but i wanted to know if anyone had any helpful hints on getting the dash out or maybe a online pdf i can print off or really anything. thnks all
Justin.
"2000 blazer. 4.3 vortek v6 2wd, aftermarket ecm tcm. flowmaster dual exhaust no cat. 2 12 inch infinity subwoofers, 1500watt bazooka amp,"
Justin.
Hi bama, sounds like your right. if yours is similiar to mine it would take about 3 hours taking your time and thinking as you go. i,m not sure if the methods are the same between the different years so maybe someone else can help with procedures good luck
I just did this yesterday so its really fresh in my mind.
remove kickpanels
remove 4 bolts (5/8) on steering wheel. drop it down in the seat.
remove 1 bolt on each end of dash at base (10mm)
unclip underdash harnesses
remove dash speaker grills and dash vent, remove 4 screws in them ( two in center, one in each speaker opening).
dash will swing forward
unclip wire harnesses behind dash.
pull out dash
there are a bunch of 7mm hexheads around the heater core compartment
open it, replace core, reassemple.
re-install is reverse.
its actually really easy, just reall scary the firstime.
remove kickpanels
pull out dash
In regard to removing the "black box" around the heater core; make sure you remove ALL the screws, there are a couple on the left side that can be hard to find. I suggest using a flashlight to look around the edge and make sure you get them all. Then pull gently in a tugging fassion; pull, let loose, pull, let loose, as the seal can make it kinda not want to come loose, just be delicate with the seal. after you get the box off there are five screws for the core itself, 2 on each bracket and one that holds the bracket that holds the pipes in place. BE SURE you re-install the pipe bracket securely or you may damage the core when you reinstall the hoses.
I'm at the removing the black casing part, just taking a smoke break.
So to get this correct, I do NOT need to remove the WHOLE entire core box with the core inside? (Meaning no need to go engine side and remove all the bolts?). So far I think I removed 5 little gold 5.5 mm bolts that hold the top half of the casing on. The far one behind the glove box was a B****...one click on the wrachet...ugh!
PS I have a 2000 blazer ls, with AC (even though it doesn't work).
There are way too many different instructions for different models to do this. It'd be cool if they could be sorted by year/options....holy.
On a good note, my dad is a mechanic and so far I haven't called him for help! I love this forum!
i just got done two days ago. you need to losen the box enough to be able to lean it back to get the old core out. there is one bolt coming from the engine compartment that is behind the air conditioning stuff. It took me for ever to find it. the easiest way to get to it is split the heater coer box by removing enough of the the 5.5 mm bolts that will allow you to reach through . there is a large square hole in the fire wall that gives access. if you do it this way make sure all the damper doors work properly after to put the box back together.
