2000 ZR2 Fender Flare questionnaire
Hey everyone.
The fender flares on my ZR2 are looking weathered. Is there a way to paint them without it looking like a 4th grade science project? I have seen some people on the site with them in black. |
use a product called "Back to Black" OR look at the DIY section for painting tips. It's not tough :D
If you go to paint them...
Take them off Sand them with 800 grit sandpaper so you don't scratch the pastic Apply 3 light coats of primer, 15 minutes between coats. Wait 1 hour Apply 3 light coats of your main paint color, 15 minutes between. Wait 1 hour Apply 3 light coats of clear, again, 15 inbetween. Should look good if you took your time :) |
Back to Black will not work on the flares as they are painted.
And the best way to paint them is as above, but MUCH easier to leave them on the fenders and tape everything else off. To remove the front flares correctly you have to remove the fender first. If you want to paint them as close to the original color as possible, use Duplicolor's Specter Gray paint. |
yeah, makes sense... i was thinking the black vinyl flares for the back to black stuff. the painted ones would not benefit much huh :icon_redface:
hello the best way is to take them off find a body shop that uses basf/rm diamaont paint they can get proper formula for the grey and clear them with a low gloss clear they hold up great. thanks and good luck
| All times are GMT -5. The time now is 06:50 AM. |
