4 door rear door pannel
Old Feb 11, 2010 | 06:06 PM
flipzat's Avatar
flipzat is on a distinguished road
Default 4 door rear door pannel
How can i safely remove this with out breaking anything. I got the bottom part off good , and i only seen one screw behind inside door latch
1997 blazer 4 door
Old Feb 11, 2010 | 06:38 PM
Go to your favorite parts store and get a trim panel removal tool (little pry bar with a forked tip and a handle). This will make releasing the push pin style fasteners much easier and less likely to break things.
Then start by looking in the grab handle for a little trim cover. Pry that up and remove the two screws in there.
Once you are sure you have all of the screws out, work your way around the panel starting at the bottom sliding the removal tool around feeling for the push pins. Once you get to a pin, center the opening in the tool around the pin and then pry to release it. Continue until they are all released.
Old Feb 11, 2010 | 06:46 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
There should also be two strips that run vertical on either side of the window to the roof. You need to be sure to take those off or the panel ain't comin off
e602
91
Mar 8, 2015 04:53 PM
crooner316
Feb 16, 2015 07:51 PM
Ryan02Stang
Jun 20, 2012 05:00 PM
brino1
Feb 25, 2011 08:05 PM
1baggedblaze
Apr 13, 2010 04:52 PM
