4x4 into Zr2
Old 04-05-2008, 10:50 PM
WolfPack's Avatar
Default RE: 4x4 into Zr2
I want your axles...I want them so bad.
  #22
Old 04-05-2008, 11:48 PM
5speed is an unknown quantity at this point
If I ever take them out, I will let you know Wolfpack.
  #23
Old 04-06-2008, 10:12 AM
WolfPack's Avatar
Haha thanks
I just wanna put in lockers...and it's tricky for the 7.625...and impossible with the aluminum front diff [>:]
  #24
Old 04-09-2008, 08:19 PM
ElCaminoManT is an unknown quantity at this point
is the zr2 suspension not interchangeable? i mean, if you were able to find one in a bone yard, could you snag the front suspension and rear axle?
  #25
Old 04-09-2008, 08:41 PM
You could use the rear axle, but that is it. The front suspension will not fit on a regular 4x4 frame.
  #26
Old 04-09-2008, 08:43 PM
willjones's Avatar
No the frames are different between zr2s and non zr2s. The sr2 frame is bigger and the mounting brackets are different aswell. Its not worth the work for 3 inches. You may aswell just get the rough country 2 inch lift and do a b.l. Then you would have plenty of room for 31s 32s or even 33s with trimming.
  #27
Old 10-07-2008, 01:43 AM
PJT2007's Avatar
PJT2007 is an unknown quantity at this point
I am struggling to find Flares for a 2000+ 4Door as well, i looked at that link above and it only brought up a trail blazer.Thats not what i need. What does this guy have?(SEE PIC) (i found this on the Net. Here is what he wrote: Body Lift – Bushwacker flares. Manik F guard. PIAA 520’s. Safari rack. Smitty nerfs. 30950R15 Michelin. LTX AT’s on MT classic II’s.
I got on the bushwackers website and they said that only the front 2peice set would fit a 2002 4 door, They only one varity fits the 4door blazer. That sounds odd to me. I need to find a way to get some legit flares on a 2002 4 door. I am losing hope on the net.
  #28
Old 10-07-2008, 08:31 AM
WolfPack's Avatar
The only company I've seen that makes flares for a 4 door is EGR. I've got the link saved somewhere...I'll see if I can find it.
But as far as them being 'legit' or not....
Edit: Got em. CLICK ME. EGR apparently does not make these anymore though, which is why the link I posted on the first page of this thread no longer works.
wanabmudder00
12-12-2013 12:45 PM
RickBlazer
06-23-2011 04:59 AM
poepoe624
01-10-2010 11:48 AM
Boiler_81
12-02-2008 10:04 AM
88s10Blazer
01-09-2008 04:34 PM
Quick Reply: 4x4 into Zr2
