99 Blazer passenger park light lens removal
How do you remove a park light with foglight on a 99 blazer 4door 4wd? it the front passenger side
Hello i belive that you will have to open hood pull out grill it is held in with push in metal clips i belive 8 clips you may have to pull hard be carefull on ends below headlamps they will break, clip at end of grill by fender once grill removed you should see a sqeeze type clip holding one end sqeeze it and remove then sqeeze and turn lamp sockets for removal. the lens part is part of lamp assy thanks and good luck
