Adding an additional light to 2nd Gen turnsignal assemblies
I could never understand why GM made two reflector buckets in the 2nd Gen S-series turnsignal lights and then just leaves one empty. And of course when you get the clear turnsignal lights it looks even more noticable. So I decided to fix this small shortcoming. I searched on a few forums and haven't seen this done yet. So here goes..
First I got a couple pigtails for $1 each at a recent swap meet. http://img.photobucket.com/albums/v3...r/100_1395.jpg I took the TS assemblies, layed out some Dykem fluid, made a center mark and eventuall drilled a pilot hole. http://img.photobucket.com/albums/v3...r/100_1393.jpg http://img.photobucket.com/albums/v3...r/100_1404.jpg Next using a step bit, enlarged the hole to 5/8". http://img.photobucket.com/albums/v3...r/100_1405.jpg Using a couple small flat files and notched the hole for the two tabs on the bulb socket. http://img.photobucket.com/albums/v3...r/100_1407.jpg The TS bucket material is too thick for the sockets to turn and lock so the back of the bucket needs thinned and flattened all at the same time. http://img.photobucket.com/albums/v3...r/100_1408.jpg It's pretty much file, test fit, file some more, test fit, etc until... http://img.photobucket.com/albums/v3...r/100_1409.jpg http://img.photobucket.com/albums/v3...r/100_1411.jpg One done, now to do the other side. http://img.photobucket.com/albums/v3...r/100_1414.jpg Both done... http://img.photobucket.com/albums/v3...r/100_1420.jpg http://img.photobucket.com/albums/v3...r/100_1416.jpg Installed... http://img.photobucket.com/albums/v3...r/100_1425.jpg I just need to wire them and buy some amber bulbs to compliment my amber TS bulbs. Later, Doug |
Nice work. Just for the record, this was the location for factory fog lights on the lower trim trucks.
Very nice work!
and a very nice write up saved yourself $150! so yeah.... I whimped and bought these instead http://www.lmctruck.com/icatalog/cst/full.aspx?Page=73 sad part is... I think I like yours better... 0_o Someone sticky this er something.... |
Not nearly the response here you got on S10 forum.
Nice work! I may have to look into this.
Next year I am buying some signals off ebay. They are black all the way across but are supposed to be slatted to let light through. Im not sure how well it would show through. Adding a second bulb would give me some insurance. |
Nice work... that was actually the location i mounted two of the six strobes i have on my blazer.
Originally Posted by Zeeke98
(Post 250691)
Later, Doug |
I did the same as you DriftinBlzr, only thing is, I didn't like the small bulbs so made the holes bigger & bought 2 turn lamps from a wreck & fitted them. Now they match & I have dual turns.
Next step is to fit a relay between them so they flash intermittently. I think that'll look cool. Just had another look at your pics. Did the ones you have, have the 194 bulb? Which is why you fitted the same again. If so then my lights are different to the US ones. Mine are used as turn signals. |
No, they are turn signals and the other bulb is the larger 3157 type. The 194 bulb that's already there is the one in the corner of the headlight. The 194 sockets are easy to find new at flea markets/swap meets. The larger 3 wire sockets you have to get from a junkyard or try to find them at a parts store(and they're pricey).
