Bent bumper
Old Sep 8, 2008 | 04:26 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default Bent bumper
was wondering if there is an easy approach to bending back a bumper? the drivers side is actually pointing downwards a bit. passenger side is nice and even. do i have to take off the valance to bend the bumper back or is there a diff way of doing it? i can even see a diff from the front of the tire to the valance. 2inch gap on drivers side compared to i would say maybe 4 or so on the passenger side. i'll take pics if needed.
Old Sep 11, 2008 | 07:16 PM
Numba1Sean's Avatar
Default RE: Bent bumper
Anyone??
Old Sep 12, 2008 | 06:27 AM
There is no easy way to do this other than unbolt it, and bolt on a replacement. Bending a metal bumper back to the proper shape is not going to be easy with common hand tools. If you had some hydraulic tools , it could be done, but you still should remove it to keep from damaging the body. The problem with a down turned bumper is that you will have to lift i past where you want it due to spring back. The body will get in the way. Take it off and now you have a problem of how to hold it...
I would go to your local junkyard and grab a replacement. Should be plentiful.
Old Sep 12, 2008 | 10:07 AM
Numba1Sean's Avatar
yea but where are the bolts and how do i get the valance off? well i seen 2 bolts for the bumper itself and i know there has to be more then just those 2. the valance is the biggest pain in the butt for me anyway.
97Beater4WD
Feb 4, 2012 08:11 PM
doelleb85
Jan 11, 2012 12:34 AM
94camaro
Dec 15, 2008 07:32 PM
blazerboy124
Nov 6, 2008 10:47 PM
KFC_Or_Bust
Dec 2, 2006 03:23 PM
