blazer roof racks?
I'm no expert on roof racks, as you can see, I have no roof rack!!
Are you looking a wiring harness for aftermarket fogs, or stock fogs, or are you wanting to install factory fog lights on a non-foglight equipped Blazer? Most of the time when you buy foglights, the wiring harness comes with it. If it is factory foglights and you have damaged or missing wire, I can't help you, I have no idea. The best I can tell you is to get some form a junkyard.
That link helps but they are not nessacarily for less. I would say if you have the tools to, fab up your own basket, it would allow for a more custom basket and you could incorporate things such as shovel rack, spare tire rack, tiedown anchor points, etc. into it and would probably cost you less. Then for a durable finish you could have it rhino lined or what not. Just my opinion.
-Lenny
-Lenny
Definitely agree with Lenny on the Rhino Lining. I was looking at that today. It runs about $30 for a quart of it, and there are a huge range of car parts and accessories that could benefit from it. Waterproof, Rust proof, Durable, Doesn't Scratch, Adds a sure footing where needed.........and the list goes on.
Yeah I am going to use rhino lining or some type of do-it-yourself truck bed liner on the frame rails, possibly the wheel wells (will have to see if that will work, it should), lower rocker panel (just below where the doors end), inside the lower door frame and lower door edge, maybe the roof racks (but they are in good shape for now), the towhooks, and eventually the trailer hitch once I get it cleaned up.
-Lenny
-Lenny
86 biscut
Aug 20, 2011 08:18 PM
