blazer roof racks?
Old Jul 24, 2007 | 06:34 PM
sasquatchfound's Avatar
sasquatchfound is an unknown quantity at this point
Default blazer roof racks?
Does any one know of any links to company's that make roof rack specifically for blazer's? Also were can i get wire kits for fog lights?
Thanks,
Old Jul 24, 2007 | 08:56 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: blazer roof racks?
I'm no expert on roof racks, as you can see, I have no roof rack!!
Are you looking a wiring harness for aftermarket fogs, or stock fogs, or are you wanting to install factory fog lights on a non-foglight equipped Blazer? Most of the time when you buy foglights, the wiring harness comes with it. If it is factory foglights and you have damaged or missing wire, I can't help you, I have no idea. The best I can tell you is to get some form a junkyard.
Old Jul 26, 2007 | 01:33 PM
BrianMichaels1's Avatar
BrianMichaels1 is an unknown quantity at this point
Hmm if you are wanting a replacement for the typical peeling one just sand it down and paint it gloss black like I did
Old Jul 26, 2007 | 01:58 PM
I was wanting after market fog lights that i can wire up to my light switch. Also the roof rack i'm refering to is like the custom ones with a basket type set-up.
Thanks,
Old Jul 26, 2007 | 02:29 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
http://roofracks4less.stores.yahoo.net
See if that helps!
Old Jul 26, 2007 | 02:50 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
That link helps but they are not nessacarily for less. I would say if you have the tools to, fab up your own basket, it would allow for a more custom basket and you could incorporate things such as shovel rack, spare tire rack, tiedown anchor points, etc. into it and would probably cost you less. Then for a durable finish you could have it rhino lined or what not. Just my opinion.
-Lenny
Old Jul 26, 2007 | 03:16 PM
Definitely agree with Lenny on the Rhino Lining. I was looking at that today. It runs about $30 for a quart of it, and there are a huge range of car parts and accessories that could benefit from it. Waterproof, Rust proof, Durable, Doesn't Scratch, Adds a sure footing where needed.........and the list goes on.
Old Jul 27, 2007 | 02:00 AM
Yeah I am going to use rhino lining or some type of do-it-yourself truck bed liner on the frame rails, possibly the wheel wells (will have to see if that will work, it should), lower rocker panel (just below where the doors end), inside the lower door frame and lower door edge, maybe the roof racks (but they are in good shape for now), the towhooks, and eventually the trailer hitch once I get it cleaned up.
-Lenny
er0ck273
Aug 6, 2014 10:11 PM
psacobie
May 27, 2014 07:52 PM
blazin=blazer
Dec 11, 2011 08:16 PM
86 biscut
Aug 20, 2011 08:18 PM
firemansc32
Mar 8, 2008 06:07 PM
