body lift!???
Old Oct 23, 2011 | 10:38 PM
hearnski's Avatar
hearnski is on a distinguished road
Default body lift!???
if anyone can help me with this ill be so happy.. i put offset rims on my blazer and if i go threw a dip in the road to fast my tire hits ontop of the fender! i was hoping to find out if anyone knows how much play i have when putting in a body lift before i would have to do any major adjustments any help would be great help
Old Oct 23, 2011 | 11:04 PM
Red 96''s Avatar
What are you referring to when you say "play" after the installation?
Old Oct 23, 2011 | 11:15 PM
hearnski's Avatar
i mean how much of a lift can i put in before i have to change linkages and stearing or anything like that
Old Oct 24, 2011 | 08:42 AM
Red 96''s Avatar
Oh, alright. I'm pretty sure that for the second gen S-series, they only have a 2 inch BL. That doesn't mean that you can't make larger pucks fit, but at 2 inches, you don't have a to change anything, just re-route a few things to make some extra room. At least, thats what I ran into during the installation of mine. Hope that helps!
Old Oct 24, 2011 | 04:20 PM
hearnski's Avatar
yes this does help lots! thanks a million ill be sure to post some pictures when its done
Old Oct 24, 2011 | 09:35 PM
Red 96''s Avatar
Sounds like a plan, good luck!
Old Oct 24, 2011 | 10:07 PM
Rottidog's Avatar
Don't forget bumper brackets - with a 2" bl & like Red said it doesn't mean you cannot put a 3" bl in. Just be ready for bumpers at stock height & possibly lengthening gas filler tube, lower fan shroud will be gone, bottom rad hose will be close to stretched to max.
I know this because the 2002 LS I got 3 years ago had a 1st gen 3" bl installed. I saw all this AFTER I got it. Only real issues are the bumpers at stock height (bumper brackets for a 2nd gen with a 3" bl are non existant) & the lower fan shroud.
Everything else (so it seems) stretched/fit.
Just think of what's attached to the body & what's attached to the frame. Take a look around the blazer... what's attached to the frame has to have enough give to make up for the body lift. That PLUS what's attached to the suspension?! Brake lines, wiring harnesses...
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
