Brake Light Strip
I'm unsure exactly what these are called but I see them from time to time. It's a strip of lights similar to the 3rd brake light that can go between the tailgate and the bumper. What I'm wondering is if that will fit on a 98 blazer and how would you go about hooking them up?
I have completely clear taillights that light up red with my led lights (white when lights aren't on) and would like to put a decal on my third brake light of some kind. However I think that would take away from how much red light the back of my suv is putting out. It has a dark brown/purple hue so at night you can't see it too well. Any thoughts?
BTW- My boyfriend has a 97 2-door Tahoe and I'm wondering if anyone knows if they would fit that too? He has barn doors instead of the tailgate however.
Thanks
Thanks
have you seen the new fire and ice lights?? I`ll try and get the link unless someone else responds first with it..
http://cgi.ebay.com/ebaymotors/60-LI...spagenameZWDVW
Typically they can be purchased to plug into a 4 pin trailer harness. Even if you do not have a trailer harness right now, you should have the wiring stuffed up under your truck to add the plug...
Also Davtak has one on his Blazer. The newest fire and ice ones have red brake lights, white reverse, and amber turn signals.
You should measure up the width of the opening of the tailgate and go from there on getting one, I think you would need to get the 48" one and not the 60" one. The come with a plug to plug into you trailer harness, otherwise you can splice into the trailer harness wiring and hard wire it. Personally I would just splice into the harness wiring and add a secondary plug, that way you can sell off the LED brake light if you dont want it later.
Yup, I have one. It's only the brake light though. I have the ultra white APC bulbs as the reverse lights. Check out the pics on my cardomain page. Link is in my sig.
I believe they are made to fit any suv. Just measure it to make sure before you buy it. The 48" one should fit on yours because i believe the 94 and 2000 are similar in size.
