Brush guard question
This has probably been asked and answered before, but I couldn't find the info I'm after using the search.
I have a 1997 Blazer. At some point, I'd like to put a brush guard on it. There are only a few vendors out there making them for the 2nd gen, and the ones I've found fit 1998 and up. Will the +98 guard fit my truck? I realize I may have to fab some brackets, but I'm not sure what the differences are between the models. I know the front end difference, but surely the frame itself isn't different, is it? Do the bumpers mount the same way? Thanks. |
westin makes one for like $124 found here
this stuff makes this guy stick to your truck you can poke through some of these options |
Thanks for the links, ABN31B. I can't see the first link you posted, the site says the store is down at the moment. On the rest, I didn't see what I was looking for that says it fits a 97. I'm wanting a full brush guard, like the Hunter ones that are popular around here. I do like the looks of those stingers on that one page, though...
I looked at the 97 and 98 bumpers at LMC and it looks like they mount to the frame the same way. Maybe the difference in the brush guards is because the bumper shape changed slightly? |
the first one is a full sized brush guard (with the wings for the headlights) LINK FIXED
and these were added to show some part numbers and such |
Originally Posted by ABN31B
(Post 397500)
i aim to please.
I think you should be okay with a 98+ guard. I just put (what I think was) a 97 guard on my 98 and it seems like its designed more for the smaller lights with separate turn signals like the 95-97 have. The thicker top and bottom bars are closer together which seems to block some light on mine because it's right in front of the headlight. The 98+ guard should have more space between the main upper and lower bar to accommodate the taller turn signal/headlight assembly which shouldn't affect yours at all. Hopefully that all makes sense lol
Here's a shot that kind of shows what I was talking about, with the smaller and more centered headlights, this guard would fit perfectly. This guard does also interfere slightly with the front of my bumper so, like you mentioned, that could be another factor. http://img502.imageshack.us/img502/7794/guard.jpg Also, if you can, take some pics of the very front of your frame near the front body mount. I'd like to see if the 97 is really any different than the 98. I have pics i can post of the 98+ frame if you'd like to see them. |
Thanks for the pic, mdehoogh. Your guard looks like it needs to pivot upwards a little, then it wouldn't interfere with the headlights. Maybe if you got some 1/4" plate and fabbed up some new lower brackets?
Here's a pic I took of the front end while I was straightening out my front bumper. If you need me to take pictures from another angle, let me know. http://img819.imageshack.us/img819/1570/006hf.jpg |
Your frame looks pretty much the same as far as where the body mounts and holes are and the front 4 bumper mounts are exactly the same. If the lower bumper mounting holes are on the backside of that front body mount, then the frames are almost identical. It's probably safe to say the only difference in the guards is aesthetics and how they line up with the grill and lights.
http://img829.imageshack.us/img829/3138/cornerframe.jpg And yeah I'm gonna adjust my brackets slightly and cut into my bumper to pivot it a little more but I'm not sure how much it will help. |
I'll take a pic from the same angle as yours here in a little bit and post it so we can compare the two.
*EDIT* This is as close to the same angle as I could get. Everything looks the same to me, except for the bumper brace. Ugh, look at the oil leak :( http://img811.imageshack.us/img811/8310/066lu.jpg |
Awesome it looks exactly the same. I even have oil in the same place behind the sway bar mount haha. Green dots in the pic below are where mine mount. I've also seen some that mount at the two bolts just outside the skid plate bolts and some that attach to the bottom of the body mounts
You shouldn't have any problems with the 98+ http://img197.imageshack.us/img197/6426/62816499.jpg |
damn dude :icon_eek:
shes gonna bleed to death |
(Post 397800)
shes gonna bleed to death I checked the oil and it's still full though. I thought maybe it was the power steering leaking, but it's dry around it. I think one of the oil filter lines might be leaking a little bit. Whatever it is, it looks much worse than it is. Maybe I should undercoat it like mdehoogh did so it won't be so noticeable :icon_teeth: |
