Cargo area
I panted my whole floor board in the 2door I had. The carpet is in 2 pieces. Front and back. Wasn't too bad. I used some rustoleum hammered. Worked great and dried quick. I don't think I have any pictures though. I'm sure if you wanted to you could just cover the wires with some sheet metal or a piece of plywood in the back. To take the carpet out, take off all the trim and rear seats. Its pretty easy. I powerwashed my carpet when It was taken out. I'll see if I have any pics.
Well heres a thought. You could proly find a material or cloth of some sort then lay like seran wrap down under the material. then rhino line the beejebus out of it! I have a buddy who used to sparay that stuff and I tell you IT IS STRONG! I've seen viehicles litteraly held together with spray in bed liner. works great for dampening and stopping bass rattles. Just a though, and a quick one at that, proly would need to be research farther. but I suppose the finishe prodect would be removable and contoured to the back of the rig.
emphasising what Wolfpack said though, the wiring harness runs across the floor in the 4dr. Do you really want to rhino-line over that? If you have any problems with the wiring after you'll have one hell of a time getting to them through the liner, then you have to fix it after. If you do rhino line I'd personally re-route that harness along the side of the truck. You could probably expect cutting/soldering if you do though... Diamond plate would look cool but I can see it scratching up before long.
