-   -   clear corner lenses (https://blazerforum.com/forum/paint-body-interior-39/clear-corner-lenses-444/)
victoryredblazer Feb 28, 2005 08:53 PM
clear corner lenses
What would be the easyest way to replace the yellow corner/turn lights with clear lense/ yellow bulb lights? Can I get at them from inside the wheel wells? Or under the bumper maybe?
Question #2: How hard is it to wire fog lights? Could I just stick them in the tow hook openings and splice them into the head light wires? Or would that short out the system? My silverstars are 65 or 55watts a pop @ 12.8 volts....thats like 5 amps so if I put in 50watt fog lamps it might spike to 10 amps.... I wonder if its a 10amp fuse or a 7.5?.....
EDIT: PS I have a 2000 2dr 4x4.
01xtreme Feb 28, 2005 09:08 PM
RE: clear corner lenses
I don't know about the fog lights but the clear turns are EASY to replace. I'll double check on how to replace them...it's been a while since I changed mine out.
victoryredblazer Feb 28, 2005 11:23 PM
Thanks for any help. I think they are an easy exterior improvement.....something about yellow lights and red paint.....
01xtreme Mar 1, 2005 01:09 AM
I'll check it out tomorrow...too dark now
akennedy1984 Jul 23, 2005 12:57 PM
Clears are EASY to install. I just did mine about 3 weeks ago. Here is how to do it:
1. Remove the tabs that hold in the headlights.
2. Remove bulbs from headlights.
3. Once headlights are removed, remove bulbs from turn signals.
4. To remove turn lenses, turn them away from the truck (Ex. If removing passenger side swing out to the left).
**It may seem like you are going to break them...but don't worry they won't break!!**
5. Change bulbs to amber.
6. Remove grill. (This aids in the re-installation of headlights)
7. Install new lenses.
8. Re-install headlights.
9. Re-install grill.
10. Test lights and you're done!!
Took me about 30 minutes to do mine. It's an easy upgrade the dramatically improves the exterior appearance. As far as the fog lights go I have NO idea.
FatRyan Jul 25, 2005 02:50 AM
^^^ WTF? dude, it seriously takes like 30 seconds to switch out turn signal bulbs on our model blazers. all you do is remove headlights (by pulling 2 retainer clips out), then reach down and remove bulb on turn signal housing. you dont need to unplug the headlights or remove grill. its seriously freakin easy as hell.
mharrison Aug 1, 2005 05:41 PM
He's changing lenses, not just bulbs.
FatRyan Aug 2, 2005 08:51 PM
it doesnt matter. its still easy and fast. the turn signal housings are held in by 1 clip. it takes all of 1 more second to take the housings out.
LORCLAS Aug 3, 2005 04:41 PM
Get Silverstar replacement bulbs for the turn signals. They are a clear/blue color so they look good with the clear lenses, but turn amber when activated so you are still legal.
deadpool Jul 29, 2006 01:17 AM
anyone know how to do this on a 95 blazer with the sealed headlights?
