clear corner lenses
Old Feb 28, 2005 | 08:53 PM
victoryredblazer's Avatar
victoryredblazer is an unknown quantity at this point
Default clear corner lenses
What would be the easyest way to replace the yellow corner/turn lights with clear lense/ yellow bulb lights? Can I get at them from inside the wheel wells? Or under the bumper maybe?
Question #2: How hard is it to wire fog lights? Could I just stick them in the tow hook openings and splice them into the head light wires? Or would that short out the system? My silverstars are 65 or 55watts a pop @ 12.8 volts....thats like 5 amps so if I put in 50watt fog lamps it might spike to 10 amps.... I wonder if its a 10amp fuse or a 7.5?.....
EDIT: PS I have a 2000 2dr 4x4.
Old Feb 28, 2005 | 09:08 PM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: clear corner lenses
I don't know about the fog lights but the clear turns are EASY to replace. I'll double check on how to replace them...it's been a while since I changed mine out.
Old Feb 28, 2005 | 11:23 PM
Thanks for any help. I think they are an easy exterior improvement.....something about yellow lights and red paint.....
Old Mar 1, 2005 | 01:09 AM
01xtreme's Avatar
I'll check it out tomorrow...too dark now
Old Jul 23, 2005 | 12:57 PM
akennedy1984's Avatar
akennedy1984 is an unknown quantity at this point
Clears are EASY to install. I just did mine about 3 weeks ago. Here is how to do it:
1. Remove the tabs that hold in the headlights.
2. Remove bulbs from headlights.
3. Once headlights are removed, remove bulbs from turn signals.
4. To remove turn lenses, turn them away from the truck (Ex. If removing passenger side swing out to the left).
**It may seem like you are going to break them...but don't worry they won't break!!**
5. Change bulbs to amber.
6. Remove grill. (This aids in the re-installation of headlights)
7. Install new lenses.
8. Re-install headlights.
9. Re-install grill.
10. Test lights and you're done!!
Took me about 30 minutes to do mine. It's an easy upgrade the dramatically improves the exterior appearance. As far as the fog lights go I have NO idea.
Old Jul 25, 2005 | 02:50 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
^^^ WTF? dude, it seriously takes like 30 seconds to switch out turn signal bulbs on our model blazers. all you do is remove headlights (by pulling 2 retainer clips out), then reach down and remove bulb on turn signal housing. you dont need to unplug the headlights or remove grill. its seriously freakin easy as hell.
Old Aug 1, 2005 | 05:41 PM
mharrison's Avatar
mharrison is an unknown quantity at this point
He's changing lenses, not just bulbs.
Old Aug 2, 2005 | 08:51 PM
FatRyan's Avatar
it doesnt matter. its still easy and fast. the turn signal housings are held in by 1 clip. it takes all of 1 more second to take the housings out.
Old Aug 3, 2005 | 04:41 PM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Get Silverstar replacement bulbs for the turn signals. They are a clear/blue color so they look good with the clear lenses, but turn amber when activated so you are still legal.
Old Jul 29, 2006 | 01:17 AM
deadpool's Avatar
deadpool is an unknown quantity at this point
anyone know how to do this on a 95 blazer with the sealed headlights?
