Door to body weatherstripping
Old Feb 19, 2015 | 07:50 AM
Smile Door to body weatherstripping
2004 Blazer 4 door
I'm replacing the driver's door this weekend because it's bent to hell and the hinge holes are opened up (previous owner neglect and damage...) as well as installing some oversized bushings at the same time to help out the hinge on the body side. I noticed the rubber stripping that runs along the top of the doors along the roof line on the left side is gashed up in places, and it looks like the previous owner tried to repair it with some sort of rubber sealant... I think they just made it worse lol. I notice it's actually stuck on with some thick 3m molding adhesive tape type stuff, so I don't think it's something I'd be able to pull off a junk yard truck and reuse... It's the rubber strip that runs all the way from the bottom of the front window to the rear or the top of the rear door, not the actual rubber on the doors, it is stuck to the body itself.
Does anyone know where you can get new ones? Or maybe even have some GM part numbers for the seal? Really need the left, but if I could get ahold of the right I might do it too.
Thanks
Old Feb 19, 2015 | 08:04 AM
Jamaroon's Avatar
LMC Truck should have it.
Old Feb 19, 2015 | 09:03 AM
Actually they do, but it's interesting they don't show a separate LH and RH side??? I guess maybe it's the same trip on either side, just flipped around?
Old Feb 19, 2015 | 09:16 AM
screw it, I ordered it. $40 shipped, if it comes in and all goes well, maybe I'll replace the RH side too
dan1964
Oct 17, 2014 08:55 PM
Fat_Phil
Mar 17, 2009 10:26 PM
86S10
Mar 22, 2008 03:29 PM
sktdarkstar8
Oct 11, 2006 03:15 AM
DetroitMuscle
Sep 19, 2006 09:08 AM
