Door Panels
Old Dec 20, 2009 | 09:41 PM
ocblaze's Avatar
ocblaze is on a distinguished road
Default Door Panels
I have a 2000 Chevy 4 dr. 2 wheel drive Blazer. I am missing some door "clips" i guess in the front doors and i was wandering if anyone knows the part numbers for those clips. The clips are the plastic things that hold the door panel to the door. Also i was wandering if anyone had a pic of the entire door panel after removal and the door itself?
Old Dec 20, 2009 | 09:54 PM
ABN31B's Avatar
dont have a part number, or a pic, but those little plastic tree-looking clips are pretty universal. take one to a parts store and match it up to a 100 count bag of em. when done, add some velcro around the edges on the inside to get a better seal.
its pretty basic once you get the trim pannel off. a speaker up front, large hole you can see the window through and some skeletonized controls and such.
what's the project?
Old Dec 21, 2009 | 09:47 PM
ocblaze's Avatar
I'm installing some speakers i bought and i need to replace those clips while i'm in there to hold to panel together correctly.
Old Dec 21, 2009 | 10:28 PM
ABN31B's Avatar
oh. yeah, if your swapping speakers, you're good then.
Old Dec 30, 2009 | 09:36 PM
ocblaze's Avatar
Does anyone know of a place to buy a new driver's door panel?
Old Dec 30, 2009 | 10:27 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default drivers door
check LMCTRUCK.COM they have a lot of parts and they do have the clips to hold the doors in, that's where I purchased mine
Old Dec 31, 2009 | 12:13 AM
RangerG's Avatar
Uh oh! This went from replacing clips to replacing a door panel. Cant be good!!
Old Dec 31, 2009 | 07:03 AM
Sisk's Avatar
Check your junk yards or pick n pulls. You can probably find a clunked Blazer that you could pull a door panel off for pretty cheap.
LMC truck tends to be fairly expensive. You'll probably pay a pretty penny for it if you buy it new.
Old Dec 31, 2009 | 08:50 AM
old skool luvr's Avatar
GL on the search through the wreckers.
not sure how the wreckers around you are, but i can't seem the find a '98 & up LT driver's door panel for mine anywhere. make sure you get the same year/trim option as your truck, 'cause there seems to be a ton of the lower ended ones around.
anyone else notice that the trim line of the p/u's don't match our Blazer's?
Old Dec 31, 2009 | 10:15 AM
Sisk's Avatar
Don't S10's have a slightly different size door?
