Drip rail / weatherstripping repair
Old Feb 17, 2013 | 02:04 PM
TY~DY's Avatar
TY~DY is on a distinguished road
Default Drip rail / weatherstripping repair
Hope I am posting this in the correct place.
Lots of things going wrong with my 98 Jimmy.
But if I am going to keep it, this HAS to be fixed:
the drip rail (right name?) that the weatherstripping
attaches to on the body around the door opening
has several spots where is has rusted away.
So the weatherstripping has nothing to hold to.
I have used gorilla snot to try & glue it back on,
but it keeps coming off.
Has anyone else had this happen - & if so,
how did you fix it??
Please help!
Old Feb 18, 2013 | 06:24 AM
TY~DY's Avatar
Here are 3 pics showing what I am talking about.
Anyone have any advice?
Attached Thumbnails Drip rail / weatherstripping repair-photobucket-22727-1361189911621_zps3e523568.jpg   Drip rail / weatherstripping repair-photobucket-52260-1361189912260_zpsb2cfc43d.jpg   Drip rail / weatherstripping repair-photobucket-70515-1361189912884_zps04f9ce69.jpg
Old Feb 18, 2013 | 10:47 AM
richphotos's Avatar
ah the weather stripping (drip rail is what goes along the bottom of the window)
but in that case, without welding in some new metal, clean the rust off with a wire brush attached to a drill, then sand it with 80 grit sand paper, then spray some rust converter primer over it.
Once that is done (let the primer dry for 12 hours) Go to an auto parts store, and pick yourself up some weather stripping adhesive. and glue it in place.
That is about the best you can do without welding in some new sheet metal.
I think it should do the job pretty well for now. It will prevent it from getting worse too with the primer/rust treatment.
Old Feb 18, 2013 | 11:58 AM
rexazz2's Avatar
+ clean the weather strip with a little acetone or laquer thinner before using any adhesive
Old Feb 18, 2013 | 05:40 PM
richphotos's Avatar
Yes, I should said that with all the rust that is most likely on it.
but i figured it would be common sense LMAO
Alaskan86k5
Jan 27, 2015 08:35 PM
KD5NRH
Sep 15, 2009 02:33 PM
dustenwolff
May 3, 2008 08:55 AM
Pokeman
Feb 19, 2008 06:06 AM
DetroitMuscle
Sep 19, 2006 09:08 AM
