driver seat question
Old Aug 13, 2012 | 11:00 AM
trixspix's Avatar
trixspix is on a distinguished road
Default driver seat question
I need to replace my driver seat and was trying to find out if I could replace my non power seat with a powered one the wire harness connector under the seat has 6 pins with wires coming to it but only 2 wires going out to the seat belt. is there a way of figuring out if a power seat would work or not.
Old Aug 13, 2012 | 12:37 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
What year is your blazer and what year did the seats come out of?
But yes any powered seat will work with your wiring harness but if you are trying to wire 95-97 seats into a 98+ blazer you will have to do some modification.
Check out my thread HERE
Old Aug 13, 2012 | 06:29 PM
trixspix's Avatar
oops my bad I thought I included some of that info this is a 2001 blazer LS at this time dont have donor vechicle because I am just at the stage of seeing if it could be done. will start looking for seat now.
Old Aug 15, 2012 | 10:55 AM
robertfireye's Avatar
robertfireye is on a distinguished road
Power seats will work fine for that. I just had a bench seat and I popped some leather power/heat/mem seats in its place on my 2000 LS Blazer. The harness you see is a full power harness, the only two being used are for the seatbelt sensor and a ground. You can do the passenger seat too, as there is a full harness for it under the carpet behind the seat. I had to cut the carpet opening for the torx bolt open a little and fish it out. Its very worth it though.
mamawolf70
Apr 10, 2020 10:44 AM
kickme005
Sep 6, 2010 06:03 PM
TheDesertFox
Nov 18, 2006 10:22 AM
USMaverick101
Oct 7, 2006 01:41 AM
Walleye
Feb 18, 2006 04:14 PM
