Emblems
RE: Emblems
hit it with a scotch brite pad, then some primer, then the paint. that way the primer hides the scuff scratches. It shouldn't peel.
RE: Emblems
x2
That is one of the most basic mods you can make, and anybody can do it with 10 minutes and some paint.
x2
RE: Emblems
cool, but how do you get it off?i looked real quick one day and wasnt too sure how to get to it.
RE: Emblems
OK. Pull the grill off and look at the back behind the bowtie, you will see two nuts. Remove them, and the bowtie will slide right out of the front of the grill.
RE: Emblems
awesome thanksyall im gonna try to do that this evening and do the "$5 billet grille" while im at it
RE: Emblems
Post up some pics when you get finished up. In fact everyone post up pics if you have done this.
RE: Emblems
well, i only have half of it done, and im a little dissapointed.there was only enough in the pack for the top half, and i had to cut notches in it b/c the vertical bars are close enough to the edge that it made it stick out and was wavy.it still looks ok from a distance but you can see where i had to cut it up close.
heres how it turned out, dont look to bad in the pic
EDIT: By rabbit0102030-Combined consecutive posts. Please use the edit feature if another member has not posted a reply.
RE: Emblems
Looks good for just five bucks!! You might need to perfect it a little bit, but everything can always use a littel work.
RE: Emblems
Here are pics of my painted grill bowtie and trailer hitch bowtie as well as
removed trim.
*EDIT by swartlkk* - switched out the picture for the automatic thumbnails as created by Photobucket. Please do not post images over 640x480 as to be kind to those members which may not have high speed internet access. If you would like to learn how to post the automatic thumbnails and link to the full res shots, please PM me.
removed trim.
