Fender trimming help
Old May 12, 2013 | 07:34 PM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default Fender trimming help
Ok got a couple of questions here. My passengers side fender on my blazer is bad so I pick up one off a zr2 s10 same color. I got all four flares. I know I've heard the s10 flares won't fit on the back but they will. My question is my tires rib because I have a 0 offset. 8 inch wide rims with 31s. How should I got about cutting the zr2 fender so it doesn't rub anymore? Does anyone have any pics of someone doing this? Should I cut the flares so they don't rub? Or if I cut the fender will the flare shape to it? Thanks.
Old May 14, 2013 | 08:48 AM
Bump. All I need to know is how should you go about trimming the fender and the flare
Old May 14, 2013 | 09:16 AM
El_Beautor's Avatar
Jamaroon shares this awesome link a lot. It's from the S10 Crew Cab site. Skidz Cut-Out Flares. It's a great walk through on trimming your fenders.
Old May 14, 2013 | 01:35 PM
Jamaroon's Avatar
That's only for no flares, with ZR2 flares you have to cut the flare. Trim a bit, test fit trim some more. Repeat until no more rubbing.
Old May 15, 2013 | 07:27 AM
Where do I cut the flare
Old May 16, 2013 | 11:57 AM
Jamaroon's Avatar
Wherever the tire touches it...
Old May 16, 2013 | 07:39 PM
Very helpful...
Old May 16, 2013 | 09:28 PM
Jamaroon's Avatar
I don't know what else you want, it's not difficult to figure out. There's no one answer on where or how much to cut. It'll be different for almost every truck out there.
Install everything, see where it rubs and cut. That's the best advice you will get.
Old May 16, 2013 | 10:02 PM
rexmburns's Avatar
Super Moderator
^x2 there's is no exact spot to cut besides where your tires are hitting. Like jam said all trucks are different.
MrRedBlaze04
Sep 29, 2011 10:13 PM
bandidolenny
Apr 15, 2010 03:59 PM
wlorton
Lifting Tech
Feb 9, 2010 02:07 AM
BGwood88
Jan 7, 2009 06:32 PM
kankoon52
Jan 13, 2008 04:33 PM
