Frontend change
1998 they changed. you looking to change it to my front end right? I'm pretty sure they make a kit for it but you'll need the headlights, bumper lights, grill, bumper and new radiator mounts. I'm not 100% sure if the actual light bulb sizes are different or not. in the end you are probably looking at spending at least $200 depending on if you get the parts new or used.
You'll need to change:
obvious stuff
-grille
-headlights
-signal lights
-bumper
-valence (plastic part under bumper)
-all the fasteners
not so obvious stuff
-rad core support
-bumper brackets (IIRC)
You have to be careful because your Core support can either be bolted on (like my 05) or be welded in, which then becomes a real PITA
I suggest you look here:
http://chevroletforum.com/forum/showthread.php?t=14500
obvious stuff
-grille
-headlights
-signal lights
-bumper
-all the fasteners
-rad core support
[quote=oktain;311980
[/quote]
I've seen this in a few threads on this topic now. What is the split between Blazers that have a welded in and bolted in support? Was it split by model years? Assembly plant?
[/quote]
