Help my high beams/driving lights went out
I was driving and I hit my high beams and pop. Both blew at the same time. I check the fuse by the driver side door and it was good. I took out the bulbs and both were blown. I changed both and still nothing. I am going to fail my British vehicle inspection because high beams are required, not sure why, but you need both. What else can I check? I need answers quick guys. My MOT, the vehicle test, is tomorrow. Where is there another fuse or switch that I missed?
RE: Help my high beams/driving lights went out
Check the switches themselves?
It would help to know what year of vehicle we are talking about.
Year aside, it is possible that your high beam switch inside the multifunction switch has malfunctioned. |
ORIGINAL: swartlkk It would help to know what year of vehicle we are talking about. Year aside, it is possible that your high beam switch inside the multifunction switch has malfunctioned. Isnt the High Beam switch a stand-alone unit? I know it was on my last car and should be the same on the S-10, its on top of the sterring column, it shares bolts with the IGN switch though, so if that switch comes off with the high beam switch make sure you put the IGN switch back on right, especially if you have a column shift. |
It's on a 1997 Blazer S10. So it could be on top of the steering column? No I don't have a column shift, it's the one in the console. I'll take apart the plastic stuff to see if it's there.
On a '97, the multifunction switch controls the turn signals, hazards (although the hazard switch is independently replaceable), and high-lo beam activation. By pulling back on the signal stalk, the high or low beams are activated. Also, the multifunction switch has the brake lights routed through them, which is a different topic.
I believe there is a headlight relay as well as a DRL (daytime running light) relay. |
Would you have any idea where it is located at?
