Help!!! No where to bolt seats
I am in the process of replacing the front floor pans. The originals were rotted through and the bolts almost completely gone ( I bought it this way unknowingly). The new replacement pans from LMC have no location to bolt the seats to. Is there something that was below the pan that I was supposed to salvage? Do I just drill holes and bolt the seats to the new pans? Please help!
Steve
Steve
The factory pans had nuts welded to larger reinforcements that were then welded to the floor. These can be made by taking some heavier steel (2" wide by 4" long or so 1/4" steel), drilling the holes and then welding on the nuts. I would drill the holes through everything and bolt the seats in, then weld everything in place.
X2. I've made the mistake of not reinforcing the floor pans when I bolted the seats down, and the nuts started tearing through the pans a couple months later. It's not so much an issue of pan thickness, rather more that you want to spread the load out over a large area. That said, 1/4" plate is pretty cheap in small amounts like that, and it never hurts to go thicker.
julioAKAjunior
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Oct 27, 2012 12:48 PM
dsrtdon
Jan 8, 2010 04:01 AM
