Minor Rust Area Repair
Old Aug 18, 2010 | 01:22 AM
STIgary's Avatar
STIgary is on a distinguished road
I recently acquired a 78 k5 that needs some restoration. It's got a lot of rust that will need to be cut out and bondo'd or welded on and repaired. Is there a process or product for this? My other concern is the underbody of the blazer. Most of the components of the frame are still intact and solid but have a lot of surface rust. I'm thinking it would be wise to treat the rust with something. I found a product called Black Star rust converter that I may try. Does anyone know anything about it or of anything better? Thanks
link to said product
http://www.mrochem.com/BlackStar-Rust-Converter.php
Old Aug 18, 2010 | 09:44 AM
Wezo2's Avatar
Wezo2 is on a distinguished road
Ive used a product called Rust Mort made by SEM. It is great for restorations and as a guy that is in the trade I really recommend this product.
Take a look at this link
http://www.dieselpowermag.com/tech/f...val/index.html
Old Feb 22, 2011 | 03:20 PM
JohnEBlaze's Avatar
JohnEBlaze is on a distinguished road
i've always had good luck with por 15....on areas that you cant take down to bare metal.. its a good preventer to keep rust from spreading
Old Dec 14, 2012 | 12:02 AM
CanadianaBlazer's Avatar
CanadianaBlazer is on a distinguished road
Thanks! I have a small 2 inch area of rust directly behind my rear passenger door, ... spring project!
Old Aug 8, 2013 | 10:40 AM
DiffBuster's Avatar
DiffBuster is on a distinguished road
This is all great information. Thank you all very much. My Blazer is still solid but starting to lose paint on the rockers and bottom of the doors. I'm thinking about using bedliner on the above mentioned areas, actually across the whole bottom of the outside, as well as the bottom of the inside of the doors and the thresh holds. Seeing as how some of you are Tradesmen and actually know what you are doing; any thoughts on using bedliner for this? Would the prep process be the same? Is spray- can bedliner just as dependable as what you would get if it was done at a body shop? I had a quote done and they wanted $1,200.00. I understand the amount of work involved and think that sounds fair(kind of). Trouble is; I would really like to do all of this myself. It's MY Blazer, know what I mean? If I can do it for a lot less than that, it would leave more $$ for other modifications. Or, is the bedliner thing a bad idea? Any experience or opinions would be greatly appreciated.
Old Apr 24, 2014 | 03:34 AM
AGodlyCanuck's Avatar
AGodlyCanuck is on a distinguished road
I saw a comment about Rust Converters?
I would just like to say that yeah, the do work... surprisingly well...
Just try not to get it on your skin...
It worked for me... Used it and did the rest of my work, had my car inspected it and it passed.
https://imgur.com/a/lXZPb
Old Dec 18, 2019 | 07:49 PM
hurleyii's Avatar
hurleyii is on a distinguished road
Originally Posted by TurboAddiction
Sorry for the late response again.
Jimmy1996,
Yes you can do that, or you can also save the time and sand blast the area.
My preferred method is a combination to lesson the mess made by sandblasting and
a good wire brush will strip 99 percent of the rust, but not actually remove the cancer 100 percent in most cases in my opinion. So I use the wire brush to prestrip it and a sand blaster to give me bare truly clean metal.
Keep in mind many don’t like a blaster cause it changes the chemical composition of steel.
Old Apr 20, 2020 | 06:47 AM
papad5370's Avatar
papad5370 is on a distinguished road
Default The cancer within..
you can do that however your just covering up the damage.
Old Apr 20, 2020 | 06:51 AM
papad5370's Avatar
Default Application
1997 Ford F350 Underbody Rust Removal - SEM Rust Mort - Diesel Power Magazine
the pics didn't pop up for me, how do you apply this?
Chic_Bowdrie
Mar 31, 2012 08:47 AM
ko2blazer
May 25, 2011 04:42 PM
bignick
Sep 12, 2010 09:28 PM
Red 96'
Jun 28, 2010 03:56 PM
MuddBunny84
Jun 24, 2010 06:35 PM
