Need help with my tail gate.
Hi I have a 96 Jimmy with the electric lock in the back door and I cant get it to open.Is there a way to remove it without having to go from the inside and take the plastic panels off.The switch is already out I was thinking of drilling a hold to get to the mechanical mechnism and see if I can open it with a screw driver if possible.Or the next option do I have to repace the switch.Thanks.
if you want to drill a hole, that is your choice, then you have a hole to fix, or you could just go from the inside, and then trouble shoot.
drilling a hole you run the risk of the hole being in the wrong area ect.
I only want to drill a hole if I know forsure Im going to be able to open it from that way.If I dont have to take apart the panels off the door from the inside I would like to avoid it if possible.My back windows are tinted and its difficult to see in the back even with light.My jimmy is in a shop thats very dark doesnt have enough lighting.
Why dont you get a work light, or use a work light inside the truck while you take the back panel off. Trust me, its a lot easier to take it off then it is to drill a hole, hope its in the right spot, and then you have a hole.
You are correct and even if I wanted to go that route it isnt possible because the drill bit wont reach back into the hole far enough.The electric mechanism or switch is still connected is there anyway I can hook a 12 volt power source to the wires on the switch and get it to open?I think theres 5-6 wires that hook into it if i remember correctly.I know it sure would be nice if I could get my tail gate to open and close like it should.
Well Im sure i`LL be working on it again tomorrow,I`ll look for the srews do you know where abouts on the door panel they are located?Im pretty sure I looked at the inside of the back before I didnt see any screws but there is that possibility that there is an oversite on my part.
on my first gen there are like 6 screws along the bottom, and then a couple on either side at the top. Would probably be easiest to follow the instructions in post 8 on the link I gave you, so you can open it. the way its done in there, you can still cover it up with the carpet back there so you cant see the hole.
