need help replacing driver window motor 02 blazer
Old Jul 11, 2010 | 08:19 AM
sweaver's Avatar
sweaver is on a distinguished road
Question need help replacing driver window motor 02 blazer
I am so impressed by this forum, thanks for having it. I just fixed my rear hatch actuator by following directions posted and it works perfectly. I am going to replace my driver side power window lift. Does anyone have step by step directions?
Old Jul 11, 2010 | 12:01 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
are you replacing the whole window regulator or just the motor? and are you using new or used parts?
Old Jul 12, 2010 | 04:06 PM
sweaver's Avatar
Default WIndow
It is a new lift motor from NAPA
Old Jul 12, 2010 | 05:04 PM
you first want to remove the door panel. you do this by removing the two bolts that are under the armrest and one behind the inside door handle. then wedge a flat blade screwdriver under the bottom of the door panel and gently pry towards you. and work your way around the whole perimiter of the panel until all of the plastic retrainers are removed. then lift up on the door panel from the bottom and the top will come apart from the track its in. now you should see the motor assembly. now you need to unplug the motor and your going to have to drill out the rivets that hold the motor in. once drilled the motor should pull out towards you and you can put the new motor in with bolts. use thread locker on the bolts so that they dont come loose. plug the connector in and put your door panel back on starting at the top, put the top part in the track then push on the door panel until all the plastic clips are in. and you should be all set
Old Jul 17, 2010 | 03:38 PM
4x4BlazerZR2's Avatar
4x4BlazerZR2 is on a distinguished road
When you perform Ryanmatt's procedure, double check and triple check the plugs to make sure they are tight. Taking it back apart and reconnecting the plug is not fun.
Old Jul 19, 2010 | 11:46 AM
sweaver's Avatar
Thank you so much! The new bolts were a problem because of the gear plate behind the hole but with a little sweat I got it mounted, thanks!
Old Jul 27, 2010 | 02:33 PM
nucas's Avatar
nucas is on a distinguished road
I have a 91 Blazer. Is the process drastically different? I also have used parts.
mamawolf70
Jul 10, 2020 03:46 PM
mamawolf70
Apr 10, 2020 10:44 AM
Shizzinizz
Apr 14, 2014 08:50 PM
cueball
Aug 4, 2009 03:12 PM
gatopescado
Dec 20, 2005 11:05 PM
