painting the dash trim and console.....tips????
Old Feb 20, 2013 | 11:26 PM
spadedjimmy43's Avatar
spadedjimmy43 is on a distinguished road
Default painting the dash trim and console.....tips????
I'm wanting to paint my dash trim, console, and some door trim. What is the best way to do it? I wanna do it properly. Best way to start obv is sanding. What grit? Do I need primer? Best kinds of primer and paint to use? Looking to do like a super glossy black finish.....no fiberglass lol.
Old Feb 23, 2013 | 03:43 PM
swanman35's Avatar
swanman35 is on a distinguished road
prep is everything. Sand, with maybe 100 grit, just scuff up the surface. I would prime it, can only help. Then flat or gloss paint, flat goea on more even but gloss will be shiny. Then clear coat will protect and make it glossy as well. I painted mine and it looks amazing. I love it.
Old Feb 23, 2013 | 04:17 PM
Steve-o's Avatar
Steve-o will become famous soon enough
100 would be to rough if you ask me.
Old Feb 23, 2013 | 06:25 PM
richphotos's Avatar
I would use 300-400 gritt sand paper, an adhesion promoter, a good primer, and then paint it. I would put a clear coat over it as well, gloss, matt or flat, depeding on how you want it to look
Old Feb 23, 2013 | 10:02 PM
swanman35's Avatar
If you don't use primer and clear coat You'll probably end up with scratches through to the factor paint after a little while of regular contact with things.
Old Feb 25, 2013 | 03:36 PM
Well I quickly decided against that after my buddy truned me onto plastidip. Fell in love with the matte finish and gonna have some fun with that.
Old Feb 26, 2013 | 04:09 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
Only thing I can add, and I think it's applicable to plastic dip as well, is clean it very good with some degreaser. If you have ever applied armor all, or a similar product, you can't clean it too much. Paint and silicone do not mix.
Old Feb 27, 2013 | 01:22 AM
I've heard rubbing alcohol and water clean pretty well. Degreaser or that?
Old Mar 8, 2013 | 10:16 PM
swanman35's Avatar
I think either would work pretty well. If you sand first then clean your pretty well set.
Old Mar 12, 2013 | 11:42 PM
tech0821's Avatar
tech0821 is on a distinguished road
What color is your dash trim already? Why not grab one from you local u pull it that's already black?
