Painting the Underside of my Blazer
Old Aug 8, 2009 | 08:09 PM
Baja Blazer 85's Avatar
Baja Blazer 85 is on a distinguished road
Default Painting the Underside of my Blazer
Well, first off, I wasn't too sure where to put this. Since it involves painting and visual appearence....well, you get it.
I just wanted this to be a tutorial/documentation on how I did this to my Blazer.
First off, you need some paint. I went to Kragen and got myself some Degreaser and Duplicolor Engine Enamel. Now....the reason why I chose Engine Enamel is because it will be able to do two jobs for me: I can paint my frame rails and high temp parts such as brakes and exhaust. Also, since I live in dry, sunny SoCal, I don't have to worry about rust. The parts cleaner will help to prep the surface.
Then I went ahead and pressure washed and degreased my painting surface. Then I sanded the rails down, and degreased them again.
I removed the drum brakes, those will be painted seperatly
Now its ready to paint! It might be a good idea to protect your drum brake internals/shoes from paint overspray....
I really like how the flat black looks on the exhaust tip
It took me about 6 hours and 4 cans of enamel to do the rear half of the truck (axle, leaf springs, gas tank, wheel wells, brake drums, frame rails), plus waiting time to let the water dry after cleaning, and the paint to dry before re assembly. Of course it takes 8 hours for the paint to fully cure.
This is what the difference is front and back.
Tomorrow, I will do the front! TO BE CONTINUED!!
Old Aug 8, 2009 | 09:36 PM
willjones's Avatar
That looks really good.
Old Aug 8, 2009 | 11:24 PM
NVANZEE's Avatar
i now know hat im gonna do to mine. Thanks
Old Aug 8, 2009 | 11:36 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
looks awesome man!!
Old Aug 9, 2009 | 12:59 AM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
looks good i'm slowly doing mine i have flat black, gloss black, and a rubberized undercoating that i'm using for different areas
Old Aug 9, 2009 | 01:19 AM
kiwiblazer's Avatar
My truck came with a rubberised coating on the chassis. I thought all Blazers were done like this. Must be another Jap conversion.
Old Aug 9, 2009 | 01:23 AM
my frame and underside has been modified from factory, and i live in a high salt area
so any undercoating i had has been worn away or cut away
Old Aug 9, 2009 | 03:22 AM
wlorton's Avatar
Baja Blazer 85 .... Wanna do my 98 4dr?
Old Aug 9, 2009 | 09:04 AM
96chevblazer's Avatar
looks good now i know what im doing next to my blazer!
Old Aug 9, 2009 | 09:30 AM
Sisk's Avatar
I agree, it looks awesome!! It might be nice to do one mine because of all the salt we have during our winters.
