Project: Dauntless Blazer
Old Nov 20, 2006 | 07:06 PM
Default RE: Project: Dauntless Blazer
I know my '00 Bravada is larger than 13 gallons... Heck, I just put in 10.494 gallons today and I was at about 3/8 tank. Last time I was at around 1/8 tank and put in over 15 gallons.
Old Nov 20, 2006 | 07:07 PM
TheGuardian08's Avatar
TheGuardian08 is an unknown quantity at this point
According to vehix.com a Chevy Blazer 2dr has a 19 gallon tank behind the rear axle, a 4 door blazer has an 18 gallon tank before the rear axle. (looked at 2002 year blazer).
I usually get 240miles/15.8gal or 15.18MPG
I usually never drive on the highway because I don't have the need to (everything is close by).
Old Nov 20, 2006 | 10:52 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
i get between 17-18 no matter how i drive i can run it like a bat out of hell or just crusie around it stays the same
Old Nov 20, 2006 | 10:53 PM
98BlackBlazer's Avatar
98BlackBlazer is an unknown quantity at this point
I have an 18 gallon tank and i have a 98 4 door
Old Nov 21, 2006 | 12:07 AM
Back to my original question... Does that setup look ok?
My biggest question is the air intake, I want something that sounds good and increases MPG.
And also where could i get a cheap push bar to mount lights to?
I like the rhino, but its a little expensive
Old Nov 21, 2006 | 01:42 AM
Loud_01_Blazer's Avatar
Loud_01_Blazer is an unknown quantity at this point
well mine must be an exception, cuz i ran mine nearly dry(to the point it was hessitating to accelerate, bad move i know but just wanted to see what i could do on a full tank) and i put 16.009 gallons in it and that was after the "top off" so i believe mine only has a 16 gallon tank......220/16=13.75 mpg that is why i think something is wrong....
Also, i looked at vehix.com and it said the 2001 2 door ls has approx. 19 gallon tank. i've never put anything over 16 gallons to fill it.. but if it did/does have a 19 gallon tank something is terribly wrong with my truck.....220/19=11.5mpg!!! According to vehix i should be getting around 19 city, and 22 highway???
Old Nov 21, 2006 | 11:21 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
I'll check into this tank size thing with my vin ... I've never been able to put more than 12.5 gallons in mine and that was on empty with a 250 mile trip reading. Sorry for high-jacking the post....but any air intake isn't going to make a very noticeable difference in fuel economy or exhaust for that matter...Mine has a K&N FIPK 2 and a flowmaster 40 series and the 2 of them together neted about 1-2 MPG at most....and all the other mods you have listed are going to decrease fuel economy if anything...additional weight and reduced aerodynamics.
Old Nov 21, 2006 | 12:06 PM
^^^^^how does it sound with the 40 series??? i wanna put an exhaust on mine but i'm afraid it won't sound good..someone suggested cutting the muffler off and that will give me an idea on how it will sound with the 40 series??
Old Nov 21, 2006 | 12:30 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
you aren't gonna get an earth shattering rumble out of this truck..... I have the 40 series, and it sounds alright.. it took almost 3 weeks for it to sound good...lol I'll get you a new sound clip today if you want..... as for the gas tank size, my 4door 4x4 has an 18 gallon tank on it...... this is standard on blazers... don't believe me??? check out this link and scroll down to standard specs and dimensions.... this is a very valuable information site for any vehicle. . . . as for a 2 door blazer, they actually have a 19 gallon tank. . . so yes the 2 door has a bigger tank. check out that link for more info on your blazer... cars.com research is a credible source..... has everything you could want to know about your blazer's stock features, capacities, and dimensions........
Old Nov 21, 2006 | 01:56 PM
lastcoupe's Avatar
Well..I just checked with my parts department with my vin and the only tank available for my blazer is an 18 gallon capacity.........this means that my fuel gauge has been inacurate (by 5 gallons!) since I bought my truck 2-years ago...and possibly since my brother bought it new!! Now I can drive an extra 100 miles per tank full...thanks for the info!
