Putting d rings on a 99 blazer?
Old Mar 15, 2017 | 03:45 PM
Wesleysanchez's Avatar
Wesleysanchez is on a distinguished road
Default Putting d rings on a 99 blazer?
I have a 99 blazer 4wd with stock to hooks. Is there a way to install d rings onto the front of it?
Old Mar 15, 2017 | 04:29 PM
rexmburns's Avatar
Super Moderator
Dig around in my build thread and you will find how I did it. Sorry I'd point to to exactly where in there but I'm not sure where lol!
Old Dec 27, 2019 | 09:02 AM
eshaw's Avatar
Sorry, old thread
Old Dec 30, 2019 | 08:22 AM
Timmins_Jimmy's Avatar
Timmins_Jimmy is on a distinguished road
Yes there is a way,
I have used 2" receiver tube from Princess auto,
Made 4 holes bolted the tubes into frame and then added D ring and shackles to it...
When making the 4 holes I lined everything up marked and drilled,
When doing the holes for the Air dampener i kept the threaded part in the frame and just added a nut and washer to it from the inside of the receiver tube.
I think i used 12-14 inch receiver tubes... and stock D rings and shackles...
Hope this helps
Old Apr 7, 2022 | 10:19 PM
Jimster's Avatar
Jimster is on a distinguished road
Wow!! That's alot of work!!! Thank you for all the details!!
Old Jun 13, 2023 | 10:03 PM
Nothing too exciting to report. I did replace the muffler and tailpipe with a Walker kit (not the Dynomax one). The installation was pretty easy but the removal of the old one sucked! I had to use an angle-grinder to get the bolts off the flange at the front end of the muffler. Before I installed these I painted them with high-temp paint from VHT. I used the primer and then painted them with the paint for brake calipers as it had a heat range for the curing that would be low enough to totally cure the paint at least on the muffler. The reason I did this was because my old muffler had started to rust and then the exit tube broke when I went over a bad pot-hole. I thought I might as well try to improve the odds of preventing new rust.
I have some vacation planed, but later this summer I'm looking to install my new NOS torsion bars and new rear springs. Then later, I hope to get the 1-ton idler arm upgrade installed.
christine_208
Jan 15, 2026 10:35 PM
c.clark.24
Mar 19, 2012 04:14 PM
mjt
Jun 2, 2011 09:53 PM
new99owner
Aug 29, 2010 10:38 PM
nasir
Nov 10, 2008 06:20 PM
