quarter panel rot 2001 2dr
Old Sep 17, 2011 | 03:57 PM
metroid_killer@hotmail.com's Avatar
metroid_killer@hotmail.com is on a distinguished road
Default quarter panel rot 2001 2dr
hey everyone i have a 2001 2dr ls blazer that is starting to get some serious rust between the door and rear tires. the rust seems to be comming from the inside out. ive grinded down the rust and blasted what i could from the cavity between the exterior panel and interior panel. i used a rust sealing rustoleum primer and then an undercoating spray then used expanding foam then a coat of bondo finally i used bed liner paint on the exterior. now the paint is bubbling again less than a year later. has anyone else run into this? maybe replace the rear quarter window gasket/ i see a million other 2drs without this rust and i clean my blazer quite often i know no matter what it will need a new panel but id like it to last a bit longer so i can fix a few other things b4 i shell out the money for cutting and welding a new panel
Old Sep 18, 2011 | 02:42 PM
NVANZEE's Avatar
mine is doing the same thing on both sides. I did find a replacement panel that is just from the body line down instead of the whole quarter panel.
Old Sep 20, 2011 | 07:46 PM
RMBlazernut's Avatar
RMBlazernut is on a distinguished road
I have the same thing happening on my 4-door..im going to cut the panel out and weld a new panel in..i tried all the stuff you did and it just doesnt keep out the moisture..so welding time..here i come..
Rick
Old Sep 24, 2011 | 08:29 AM
yea with how bad the passenger side was when i tried sanding off the rust and doing the body work i knew sometime i was gona hafta do new panels. I swear im gona get 300k outa this truck and id like the body to be as dependable as the rest of the truck has been. Ive found new panels for 60 to 100 bucks. just didnt kno if anyone may have found the source of the prob. it seems to b rusting from the inside out. maybe the quarter panel glass needs new gaskets
Old Mar 21, 2012 | 09:19 AM
sicks10's Avatar
sicks10 is on a distinguished road
Resurrection.. I have a 1996 and I need the entire rear left quarter panel. From B Pillar all the way to the slant window and from the top, to bottom. Any recomendations?
Old Mar 21, 2012 | 02:16 PM
warthogdriver's Avatar
lmc for the win!!
LMC Truck Parts - Pages 46 and 47
myZR2blazer
Jun 30, 2012 08:49 PM
scosentino88
Jun 3, 2012 07:12 PM
69chevelle
Nov 19, 2010 01:07 AM
necropenetrator
Nov 12, 2009 07:44 PM
