Rear top removal
Old May 7, 2009 | 09:18 PM
Hunter89's Avatar
Hunter89 is on a distinguished road
Default Rear top removal
I'm trying to remove the top of my 89 K5 Blazer for the first time. I've removed all of the bolts on the inside, but I can't get the top to come off. The front half of the top is lifting up and separating from the body. The back part of the top won't budge. Are there additional bolts that I'm unaware of?
Just wanted to ask before I start trying to use a wedge or something to break the seal.
Old May 7, 2009 | 09:59 PM
Just make sure that you have all of the bed rail bolts out. That should be it.
Old May 8, 2009 | 07:16 AM
oisinirish's Avatar
Maybe different on mine but there are two "hidden" top bolts at the rear of the top. Rear attaching screws for interior trim need to be removed to gain access to said bolt. Visually verified. They are all the way at the back and bolt into the top from underneath the bed rail.
Old May 8, 2009 | 07:29 AM
They are on mine as well, but without trim... LOL
Old May 8, 2009 | 07:31 AM
oisinirish's Avatar
All my trim is out for the panel replacement. Makes it easy to verify!...LOL.
Old May 8, 2009 | 07:50 AM
AllEiz0nMe's Avatar
AllEiz0nMe is on a distinguished road
while on the top removal subject...don't you also have to replace the seal every time you take the top off?
Old May 8, 2009 | 07:53 AM
You should not have to so long as it is not damaged. If it is damaged, then yes.
Old May 8, 2009 | 08:00 AM
oisinirish's Avatar
I would bet on our older trucks the first removal will be the last for said seal. Have yet to test that theory yet though....darn rain!
Old May 8, 2009 | 08:55 AM
AllEiz0nMe's Avatar
I know if and when we do take the top off of ours that the seal will have to be replaced. It leaks on both sides right by where the ashtrays are. But we're planning on taking it off this summer when we get out to wharton.
Edit:
I'm not sure if your top is the same oisin but ours has the seatbelts mounted to the roof. What the frig do you do with them once the top is off? Or are you just not supposed to have people back there with the top off?
Old May 8, 2009 | 08:57 AM
I will be removing mine in a few more weeks after which every gasket/seal will be replaced on the top before putting it back on.
