Removing Moldings And Emblems
Old Jun 3, 2007 | 11:26 AM
Arthur's Avatar
Arthur is an unknown quantity at this point
Default Removing Moldings And Emblems
I want to remove the side moldings off my blazer. I know that most of them are just taped on, but i was concerned about the rear corner moldings... are they attached with just tape as well? And if I remove them will there be holes in the body?
If I remove the emblems off the rear will there be holes in the body?
Old Jun 3, 2007 | 05:42 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: Removing Moldings And Emblems
I have removed all the emblems/moldings from my blazer and they were all taped on with doubled sided tape. There will be no holes in the body behind the emblems/moldings.
Old Jun 3, 2007 | 07:41 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
speed is right. I took mine door molding off too, but you have to watch for rough places around the molding. If there are rough places you may want to consider refinishing the door or replacing the molding.
Old Jun 4, 2007 | 09:28 AM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
I used WD40 and fish line. Soak tape with a little WD40 then run fish line behind emblem. Use a high test line and wear gloves.
Old Jun 4, 2007 | 09:42 AM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
I'veheard ofthat before, when I worked at a Peterbilt Body Shop the guys there talked about removing badges and stick-onsthat way, and theother body shop I worked at had never heard of it being done like that. I'm not sure if they used WD-40 or something else, but the fishing line is a definite. They all just bought tools form the Snap-On guy for removing trim and badges. Glad to hear it actually works and hear that someone else uses this method!
Old Jun 4, 2007 | 10:49 AM
jimbosv650's Avatar
jimbosv650 is an unknown quantity at this point
Now here's the wierd thing. I have a '99 LS which, happens to be missing the trim on the driver's side rear. There are three factory original holes for clips.
Old Jun 4, 2007 | 05:35 PM
igot10pinitis's Avatar
igot10pinitis is an unknown quantity at this point
definatly i just seen this thread and was going to say fishing line. You can get a tool at local auto body shops made for it that makes it a breeze too. glad you got them off.
I have never tried the wd40 cause most of the time i take badges off its for paint and i don't want fish eye city from the oil
Old Jun 10, 2007 | 11:15 AM
Arthur's Avatar
ORIGINAL: jimbosv650
Same here... but the door moldings came of smoothly...
What is the tool called that is used to remove moldings?
Old Jun 11, 2007 | 03:04 AM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
correct me if im wrong but wont removing the door moldings leave holes in the door?
on my jimmy they look like theyre screwed on through the door
Old Jun 13, 2007 | 07:49 PM
Arthur's Avatar
ORIGINAL: stevelknievel
You stand corrected... they are taped on... just got mine off and it looks great!
