Removing rear corner bumper piece
Old Apr 17, 2018 | 10:15 AM
canadianbacon's Avatar
canadianbacon is on a distinguished road
Default Removing rear corner bumper piece
Is there a trick or procedure I need to look for so I can take this piece off? The box that's holding my vapor canister decided to finally rust out and break, so my canister isn't really held in. I'm going to try to fix it tomorrow, so any help would be appreciated.
Old Apr 17, 2018 | 12:03 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
10 mm socket with really long extension and ujoint to remove the three nuts holding it on and you should be good... if memory serves correctly that is
Old Apr 17, 2018 | 12:15 PM
Okay, so should it just slide back and off after the nuts are taken off?
Old Apr 17, 2018 | 04:27 PM
N. Jensen's Avatar
I do believe this is correct.
I looked at getting two new ones from a Bravada while at the salvage yard. (Mine have trim on them, and when the trim is removed, leaves a big hole or two in it.)
Old Apr 18, 2018 | 11:38 AM
CWBDDSPC's Avatar
Should just pop off, yep...
Old Apr 18, 2018 | 12:59 PM
I do believe that I had to remove 4 bolts on my 4 door
Old Apr 18, 2018 | 01:53 PM
I got it fixed today. There's 4 nuts you have to take off from the inside, the bolt holding my bumper brace and there's 3 on the edge of the wheel opening, which one was hidden under my mud flap (which is useless with the amount of dirt and crap built up in the back).
Here's a picture I found to help too.
Old Apr 18, 2018 | 06:16 PM
CWBDDSPC's Avatar
Good work!
gregl316
Feb 20, 2011 01:09 PM
fernandoh
Aug 6, 2009 06:24 PM
1blkblazer422
Aug 28, 2008 10:02 PM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
