Removing valance?
With a little bit a time and patience it will come of without removing the bumper but it's probably just as easy to remove to to take it off. It's just a bunch of small bolts under there holding it on is all.
As long as you guys know that valence is designed for more than just looks..
removing it can result in..
- damage to exposed parts when off-roading
- overheating at highway speeds.. esp when towing {depending on lift}
I left mine on because everything underneath was aging and a little rusty. If I would of taken the valence off, it wouldn't have been as pretty! =P
But I was wondering about the cooling issue with the valence as well as with a body lift on. Because when you do a body lift, you are really supposed to lower the radiator for cooling purposes. But I lowered the radiator with my body lift and left the valence on and the truck seems to be properly cooled, so I can't complain.
