Rust behind tail lights - 88 Blazer
Old May 29, 2009 | 05:24 PM
themcguire's Avatar
themcguire is on a distinguished road
Default Rust behind tail lights - 88 Blazer Help - fixable ?
1988 Blazer - Full Size
I was replacing a bulb in my tail light for the first time and when I removed the lens assembly all I can see is rust. I went to LMC Truck and do not see a part to replace.
I am about to replace the tail pan and floor and would like to do this at the same time.
Any help or advise appreciated.
Old May 30, 2009 | 12:05 PM
oisinirish's Avatar
I hate to say it but it looks like, at LMC, you would need the entire bed side panel. Ouch!
I wonder if you could find a junkyard and cut out the innards behind the lens and weld it in to yours.
Old May 30, 2009 | 01:49 PM
themcguire's Avatar
Thank you for answering my question.
That is bad news.... However, both rear quarter panels have rust around the wheel wells also. There is a round spot right above the tire on the passenger side that I am unable to grind away. I have done it twice, until I hit shiny metal and 3 months later it is back.
I did drive past a junk yard in PA on Route 209 about 2 miles south of Rt 80 a few years ago that looked like it had over 50 blazers. I will call them and see if they have what I need.
Thanks again,
Tom McGuire
PS: I just found 1/2 rear quarter panels at: www.rustrepair.com for 90.47 each. The picture shows that the back section of the panel for the tail lights is there. This may be my best solution
Old Jun 1, 2009 | 07:16 AM
Yeah, I would definitely suggest finding replacement panels at a junk yard. Check out craigslist.com or other similar local for sale websites. I found a complete set of bed sides (inside & outside) for $150 with no rust and minimal damage.
Chic_Bowdrie
Mar 31, 2012 08:47 AM
cdp1250
Feb 6, 2010 01:11 PM
ff162bfd
Oct 26, 2009 11:23 AM
sidviscious
Oct 8, 2009 08:38 PM
98BlackBlazer
Aug 28, 2006 01:31 AM
