rust hole in rear passenger door into wheel well
Old Mar 23, 2014 | 09:49 AM
  #21
er0ck273's Avatar
er0ck273 is on a distinguished road
Originally Posted by satajet75
I wouldn't suggest foam its only a temp fix.If you do make sure you lay down a primer coat.Otherwise just putting on paint to a direct metal will not hold or prevent further rust.I would cut the cancer out and go the right rout.
too late for not using the foam, already bondo and primed, and waiting for paint and clear, the wheel well side is already ruberized, as i am finishing those coats today.
Im confused, putting foam inside (to sound proof), and then bondo and prime,paint,clear isnt the best option? given that welding isnt an option. should i have left it hollow (no foam)?
Old Mar 23, 2014 | 01:27 PM
  #22
newguy's Avatar
Dont worry what others say. Good for a few years
Old Mar 23, 2014 | 08:27 PM
  #23
er0ck273's Avatar
i did end up not using the screens btw...what a wast of money
when you say a few years, whats expected to happen, the bondo wont hold up? im just confused on why it wont last given i took all the rusted parts out
Old Aug 29, 2014 | 07:19 PM
  #24
Patton's Avatar
Patton is on a distinguished road
^^^ How did this work out? Getting ready to do same exact thing this weekend...tia
Old Aug 29, 2014 | 07:31 PM
  #25
richphotos's Avatar
you removed all the rust 100%? if so, it might last longer than a couple years. Either way, its not the bondo that is the problem. some of the foam likes to hold moisture, and if you missed any rust at all, and did not put any type of pre-coat down like por-15 the rust will continue to spread.
but either way, I am thinking of going the same route for some spots on the jimmy. just because of a time issue.
Old Aug 29, 2014 | 09:31 PM
  #26
er0ck273's Avatar
so far so good. i can post pictures tomorrow if youd like to see the outcome
Old Aug 30, 2014 | 09:03 AM
  #27
Patton's Avatar
Please do, I got a rotted section a little smaller than my fist in the wheel well area only visible when you open the drivers side rear door..
I pulled out as much of the damp gm foam that I could reach & vacuumed out any of the other crap in there..
filed down the edges to good metal and think I'm now ready to begin..
Old Aug 30, 2014 | 12:32 PM
  #28
er0ck273's Avatar
note: this is not perfect, given my first time using bondo and not know what i was doing, but it came it alot better than I thought
Attached Thumbnails rust hole in rear passenger door into wheel well-20140830_132042.jpg   rust hole in rear passenger door into wheel well-20140830_132047.jpg   rust hole in rear passenger door into wheel well-20140830_132104.jpg
Old Aug 30, 2014 | 09:21 PM
  #29
Patton's Avatar
Thanks very much erock, looks perfectly functional which at this point is all I need my blazer to be.. I used to wash and detail the crap out of it but no more, starting to think all that water might be the cause of my rot spot.. I'll try to post a pic of what I'm dealing with but I'm not very good at this...
Attached Thumbnails rust hole in rear passenger door into wheel well-ncm_0102.jpg
Chic_Bowdrie
Mar 31, 2012 08:47 AM
bobby099
Mar 20, 2012 07:13 PM
LRV31
Jan 30, 2012 03:38 PM
Denominator
Jun 23, 2011 10:47 AM
blazinloud
Headers, Intake, & Exhaust
May 8, 2007 11:22 PM
