Sunvisor Cover Broken
Old Jan 10, 2008 | 12:32 PM
BrooklynBlazer's Avatar
BrooklynBlazer is an unknown quantity at this point
Default Sunvisor Cover Broken
Greetings to all.
So I too have fallen victim to the sun visor cover breaking.
How do I disconnect the light.
I unscrewed the mounting and saw the wire but it semed to not have a plug and it was one piece.
How do I disconnect it?
Thanks
Mike
02 Blazer 4wd 4d.
Old Jan 10, 2008 | 12:55 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default RE: Sunvisor Cover Broken
why dont you just take the bulb out.
Old Jan 10, 2008 | 01:33 PM
mdehoogh's Avatar
there should be a connector on it. i have a 98 and there was a connector on mine, newer trucks should have it. you may have to pull the wires out of the roof a little ways to get to it.
both of mine have broken off and i actually got a few hundred dollars off the price of the truck b/c when i went to test drive it, it wouldnt start b/c the light had been on for who knows how long and drained the battery.
if you cant find a connector you can always just cut the wires. or like cliro said, remove the bulb
Old Jan 10, 2008 | 01:59 PM
Thanks both of you. I will look at it again tonight.
I will try to look for the connector again by pulling the wire out.
If not I will takeout the bulb.
If I do remove the bulb does power still go to the line.
I do not want a power drain.
Right now I have a shoe lace holding the lid on.
It seems to work just do not like it. Plus the girl needs to check her make up.
username772
Jul 2, 2013 09:09 AM
BlazinBeam
15
Jul 26, 2008 10:28 PM
Redthunder
Jun 23, 2008 04:44 PM
frankjc
Aug 7, 2006 11:12 AM
