thinking about removing plastic skirts from Jimmy
Old Apr 12, 2010 | 01:23 PM
dougg01's Avatar
dougg01 is on a distinguished road
Default thinking about removing plastic skirts from Jimmy
My 2000 Jimmy 4dr 4wd has body cladding on both doors, front and rear fenders and the rocker panels. Anyone know how these are attached other than the visible screws....? I don't want to create more work right now.
I'd like to rid the truck of these as the stuff that goes into the wheelwell uses up tire clearance.
Also....I know the rear side parts (lower rear quarter panels) will need to be replaced with non-bulging sets. The ones from a blazer should work and all I'd need to do is color-match them. Right...?
Old Apr 12, 2010 | 01:29 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
im oretty sure there are spots on the door that they clip into it might not look as smooth as you are hoping for
Old Apr 12, 2010 | 07:16 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
Yeah, lots of clips holding the body side mouldings on and probably some for the rocker clips as well.
Old Apr 13, 2010 | 11:04 AM
dougg01's Avatar
Well, that kind of sucks. Looks like the cutoff tool and the dremel will get more use....
thanks.
Old Apr 13, 2010 | 11:12 AM
Sisk's Avatar
I'm almost positive you'll end with a lot of holes to fill too if you remove them, which means lots of body work..then paint.
nate4014
Jan 19, 2014 05:12 PM
midnightrider
Nov 28, 2011 08:32 AM
01vortec
Sep 8, 2009 11:02 PM
TripleBlackBlazer
Mar 21, 2007 04:13 PM
