Tire carrier bushings
Old Aug 27, 2011 | 09:11 AM
Slimer 97's Avatar
Slimer 97 is on a distinguished road
Default Tire carrier bushings
Maby this forum can help me.
I have a 97 Blazer LS 2 door that has the spare tire mounted on a hinged rack that swings out like a door at the rear of the car.
The problem is the bushings are worn and this rack makes a lot of noise.
Where can I find new replacement bushings?
Are they control arm bushings?
Old Aug 27, 2011 | 09:54 AM
mdehoogh's Avatar
The dealer parts counter might be the best bet.
It looks like there are two bushings per bracket (#11 and #26)
11 - 12546658 BUSHING SPA WHL CARR UPR PIV PIN ST1(16) (P16) 95-05 - 2
26 - 12546658 BUSHING SPA WHL CARR LWR PIV PIN ST1(06-16) (P16) 95-05 - 2
Here's a list of the parts with a link to purchase them
1996 Chevrolet Blazer 4WD Spare Wheel Carrier, /Outside RR Mounted - TS0751501L43MW2T10516
Old Aug 27, 2011 | 10:36 AM
Slimer 97's Avatar
Yes that looks like what I need.
two of each (11 & 26) should do, Thanks mdehoogh.
Any tips on removing the old ones.
Old Aug 27, 2011 | 10:47 AM
neo71665's Avatar
Most likely they are plastic and just slide it. I can't see why they would be a press fit but gm has done funnier things
Old Aug 27, 2011 | 11:31 PM
AleroBlazer's Avatar
AleroBlazer is on a distinguished road
i just had this same problem like 3 weeks ago, its just little plastic bushings, like 18$ each i think? its easier to do if you have like a table vice or something to hold it while you smack out the old ones
Old Jan 21, 2012 | 08:42 PM
Skitzoape's Avatar
Skitzoape is on a distinguished road
are these compatiable with the older style of spare tire carriers? i have 92 and the pin retainers have mysteriously disappeared and ive lost the bottom bushings. i keep getting the 12546658 part number but not sure if it works with my application.
Old Mar 19, 2012 | 08:44 AM
gwkoch's Avatar
gwkoch is on a distinguished road
They are just plastic and push out fairly easily. My local dealership wants $14 each for a .05 piece of plastic! Even GMPARTSDIRECT wants $47 for all 4 shipped! Going to look for other options first.
Old Apr 9, 2012 | 07:03 PM
Skitzoape's Avatar
GMPartsDirect was the cheapest i found and just got them.
Old May 14, 2012 | 08:25 PM
mdehoogh's Avatar
Originally Posted by amadeus
I have looked everywhere for this view.
Thank you for posting it here.
You're welcome
The link further up has specific part numbers and you can also find a lot of other diagrams. It's easier than calling the parts desk or getting a printout of it from the dealer
Old May 15, 2012 | 12:41 AM
neo71665's Avatar
Unless there some weird detail in them anybody with a lathe (metal or wood turning) should be able to knock out 4 plastic bushings in minutes.
