Water inside car please help!!!
Old Jun 21, 2011 | 08:25 PM
rodrigomorales00's Avatar
rodrigomorales00 is on a distinguished road
Default Water inside car please help!!!
Ok so for a few days now its been raining pretty hard around here at night, i usually drive during the day so i cant see where the water is coming in from but i dry up the carpet over in the passenger side and the next day is soaked in water again, so i have to do this at least 2 times a day so it wont rotten the carpet, i peeled the carpet back as much as possible to dry it and also to find were it was coming from but no luck i pored almost 2 gallon of water but non of it came in. so i was hoping you guys might have any ideas of where to check next. also all the wire connections under the carpet are all dry the water doesnt be to be happening any where around them.
Attached Thumbnails Water inside car please help!!!-imag0429.jpg   Water inside car please help!!!-imag0430.jpg
Old Jun 21, 2011 | 08:39 PM
Where did you try pouring the water? You often must use a garden hose to actually simulate rain in order to locate leaks like this.
Does the truck have a sunroof? How are the door hinge pins on the passenger front & rear doors?
Old Jun 21, 2011 | 09:01 PM
no it doesnt have a sunroof, this is happening at the front passenger side, and the two front hinge pins are due for replacement. but the thing is that its only getting wet at the carpet, the seat is dry the door panel is dry, its going to rain again tonight so ill try to stay in the truck and see if i see any water coming in.
and thanks for the reply
Old Jun 21, 2011 | 09:06 PM
Water wouldn't necessarily drip on the seat. I would replace the hinge pins and see if the problem persists.
Old Jun 21, 2011 | 09:18 PM
ok ill order them tonight!! thank you very much
Old Jun 22, 2011 | 10:24 AM
m3ch's Avatar
m3ch is on a distinguished road
mine leaks on both sides, i know for a fact the driver side is the door pins, but the passenger side i have no idea, its all good on that side, maybe the weather strip?
Old Jun 28, 2011 | 12:24 AM
replaced hinge pins and it stopped!! thank you very much
Old Jun 28, 2011 | 06:51 AM
Glad you got it fixed! Thanks for letting us know!
supermario28
Mar 29, 2014 11:21 PM
hitechracing
Nov 12, 2012 09:07 PM
Snowmonsterdude
May 10, 2012 05:58 PM
mikeinwi
May 30, 2008 10:48 PM
fruccoman
Feb 15, 2006 07:08 PM
