Water in Tail Lights
Does anyone else have a problem with water collecting in the bottom of their tail lights? I was thinking of drilling a really small hole at the bottom of them to keep this from happening. Any remedies or feedback thoughts are appreciated.
RE: Water in Tail Lights
which lenses have the water in them? mine had water in the rev lens when i got it... I drilled tiny drain holes like you mentioned yourself.. it works fine for that problem..you can also get clear sealant and put a bead around the back section where the two parts are molded together..
i just rplaced the with after maket one. Problem solved. My reverse buld actually had water in it too. kinda cool
I had drilled a small hole at the bottom of the taillights on my old Bravada due to condensation buildup. There are supposed to be filters that allow air to enter/exit the taillight housing to prohibit the formation of condensation, but it is clear that these things do not work all that well.
cdp1250
02-06-2010 01:11 PM
ff162bfd
10-26-2009 11:23 AM
