Weldless Bumper
Hey guys, I was just wondering if it was even possibly to create a bumper without any welding.
I have no welding skills whatsoever however I would love to create my own bumper. I understand it may look tacky with bolts everywhere, but if they were correctly placed, they could look good. So, opinions? |
you could probably do it with steel pipe and plates threaded to it....not to be a smart a$$ but it sounds kinda "mad max"-ish.
not to say i havent given it some thought...i would like a "tough" looking bumper but they tend to be pricey. and in order to bend some steel to make it look angular is gonna be fun at bumper thickness...3/16" or so. |
Well, I'd probably make it in the style of https://blazerforum.com/forum/paint-...-bumper-61557/
I'm thinking just get a 3 or 4" square tube for the main part, cut it in half, grind it to an angle and somehow bolt it back together. |
I've decided to put more thought into this so I whipped up a quick basic render.
3x3 steel tubing cut and angled 1/4 inch flat steel used for bumper mounts, the bracer in the back, and the 6" tall front piece This definitely looks more possible than I before thought, and this is a nice display of what it could be. http://i40.tinypic.com/2qdq5ao.png |
Looks good so far.
How are you going to close off the ends? I like the angled look..taper the bottoms at the ends to..mor angular look maybe |
Originally Posted by warthogdriver
(Post 502654)
Looks good so far.
How are you going to close off the ends? I like the angled look..taper the bottoms at the ends to..mor angular look maybe What do you mean by taper the bottoms at the ends? -Like cut a chunk out of each side of the 6" tall flat steel on the sides to give a gradual slope from 6" to 3"? |
^^^yup...just looks cleaner with the trim
(Post 502688)
(Post 502688)
Prob pretty hard.
I was thinking of just cutting off the extra and shaping it. |
On the sides yeah, but the middle plates need to stay solid to attach the square tubing.
Change of plans, Menards doesn't carry flat steel. Home Depot doesn't carry flat steel wider than 2 inches. Farm and Fleet goes up to 3 inches, so I am going to have to deal with that. |
Bending 1/4-pain in the ass with 3 people, a welder to tack, and a bench vise
Welding gaps after using acetylene torch-pain in the ass as well New bumper with a few bends to match the front end-Priceless and looks MEAN She looks like so: might be sellin it to pj, for his jimmy (james) http://i470.photobucket.com/albums/r...th_bumper1.jpg http://i470.photobucket.com/albums/r...th_bumper2.jpg |
you can always have someone else weld it for you. i used to be in the same boat. when i did the sfa on my s10 i cut and made everything. labeled or put in place what i could and had a guy come and weld everything up
Originally Posted by j89lumaye
(Post 503322)
Welding gaps after using acetylene torch-pain in the ass as well New bumper with a few bends to match the front end-Priceless and looks MEAN She looks like so: might be sellin it to pj, for his jimmy (james) http://i470.photobucket.com/albums/r...th_bumper1.jpg http://i470.photobucket.com/albums/r...th_bumper2.jpg Bend wise, I won't be doing insane bends. I will be putting like a 5-10 degree bend in the middle of a big piece, that's it.
Originally Posted by abig84
(Post 503397)
