Wheels
Old Jan 7, 2007 | 11:20 PM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Default Wheels
Whats the bolt pattern on the 99 4x4s? And how do I know which ones will fit my Blazer? I found some 18x7.5s, will they fit? Why or why not? And what tire would you recoment on a 18-20" wheel?
Old Jan 8, 2007 | 12:38 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Wheels
the bolt pattern should be 5 on 4.75 if im not mistaken. This has been the bolt pattern on the s-series for a very long time...
Old Jan 8, 2007 | 01:45 AM
BLK85's Avatar
Default RE: Wheels
Ok thank you. Can anyone else answer the rest of my questions. And help me make up my mind, go for the bigger rims look, but dont lower it since I do, do some off roading (wouldnt with the biger rims for that) or lift it and go for the off roader look.
Old Jan 8, 2007 | 09:47 AM
Default RE: Wheels
We really need to know the offset on the rims to answer anything else. For tire size choices, do you want your speedo to still be accurate or doesn't that matter. To keep it accurate, you need to get a tire that has close to the same OD as the originals. What was the original tire size on your truck?
Old Jan 8, 2007 | 02:55 PM
BLK85's Avatar
Default RE: Wheels
ORIGINAL: swartlkk
+38 is the offset. Yes I want the speedo to be accurate. The originals are 235/75-15
Old Jan 8, 2007 | 03:49 PM
Default RE: Wheels
So you need a tire that is 29" in diameter.
At an offset of +38mm, you are sitting at 1.5" from the center of the rim to the hub mounting face. So with a 7.5" rim, you are looking at 5.25" worth of back spacing. I believe the stock 4wd rims have 6" backspacing... With these rims, the inner edge of the tire will be 3/4" closer to the frame when straight. You may run into problems when the tires are turned.
Old Jan 11, 2007 | 01:37 AM
BLK85's Avatar
Default RE: Wheels
How do you figure that? I would rather know how to figure it instead of having to ask someone all the time.
Old Jan 11, 2007 | 01:43 AM
4lowlife's Avatar
Default RE: Wheels
Easy, less backspacing = wheels will be closer to the frame.
A7.5" rim width with 5.25" backspacing means the wheels will be tucked further under the wheel well. Thus when you turn in either direction, wheel rub may occur as Kyle stated.
Old Jan 11, 2007 | 01:57 AM
Default RE: Wheels
Actually I stated that wrong in my previous post... That's what I get for posting while at work.
The more the backspacing, the further from the frame with the wheels pointed straight as this would move the hub mounting surface on the rim further from the inner edge of the rim. Where you could wind up with problems is when you turn as the outer edge of the tire now travels in a wider arc while turning.
Offset is from the center of the rim. Positive offset is towards the outside of the rim (the side you see) while negative is to the inside.
lannon_j
Tires and Wheels
Apr 7, 2014 06:23 AM
95blazerlt
Tires and Wheels
Sep 25, 2013 08:48 AM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
FattyExtreme
Aug 14, 2004 06:02 PM
