wife and i pins.
Old Aug 27, 2010 | 10:27 PM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default Pins
got the lower pin in everything rolls nice.
i watched a1auto.com where the guy compressed the spring and put s 3 ties around the spring and tightens them up.
so far i did that about 7 times and broke about 21 ties.
when i take pressure off the spring usually 1 or 2 ties tear.
i will continue to try the ties until maybe i can get the spring in that area of the door.
i am short about 1/4 inch. it looks nice and easy on the video.
everytime i hear the ties tearing i get frustrated.
maybe tomorrow i can get the spring to stay more compressed so i can slide her in where she belongs.
thanks again.......................
Old Aug 30, 2010 | 01:10 PM
well i went to Ace and got ties that have 175 lbs pressure. the standard ties that i got from Home Depot were only 75 lbs.
the ties held real well and i slipped the spring in the door and cut the tires with the wifes scrapbboking blade.
thats to everyone for your input....
Ties .................................
Last edited by swartlkk; Aug 30, 2010 at 01:20 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member has not responded prior to waiting 24 hours.
Old Aug 30, 2010 | 02:15 PM
AJBert's Avatar
So what was the problem with the bushings before and what did you do to fix it?
Old Aug 31, 2010 | 07:51 AM
Default Pins
uneven door closing
replacing some bushings, replaced all pins.........................
Old Sep 2, 2010 | 01:21 PM
JeremyNYR's Avatar
JeremyNYR is on a distinguished road
kenny, your thread gave me a headache. I should've known when even the subject looked to make no sense.
Old Sep 2, 2010 | 04:40 PM
AJBert's Avatar
Originally Posted by kennybopaloo
uneven door closing
You stated the bushing wouldn't fit in the lower hinge, and now all of a sudden they do? I'm asking for the benefit of the members on here as to what you did to fit the bushings into the lower hinge.
Did you weld on a new hinge?
Get the correct bushings?
Grind down the bushings?
Drill out the hinge?
It is always nice to let others know that once you have solved a problem, exactly what you did to solve the problem.
Old Sep 2, 2010 | 07:37 PM
the stealership gave me a lower bushing without the grooves in it. i put the lower pin in downward with out any bushing at the head of the pin. the bottom of the pin the bushing they gave me fit in the hole. i then put on the snap ring and everything is ok. door closes smoothly and no more wind noise.
Old Sep 2, 2010 | 10:51 PM
Fozzy's Avatar
Fozzy is on a distinguished road
If I remember correctly I had this same exact problem with a Chevy Astro.. the Bushings were just wrong.. had to finally bring all the old and new stuff to the dealer and plead ignorance.. when the parts are wrong.. things just wont work.. far too many parts houses simply cannot do anything but regurgitate whats on their screen..
aaronjohn20
Aug 4, 2011 03:24 PM
needabiz
Dec 12, 2010 06:40 PM
baronthered
Oct 11, 2009 12:08 AM
78Special
Jan 5, 2008 07:20 PM
