Zr2 flares
Old Oct 23, 2012 | 05:17 PM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default Zr2 flares
Can't figure out how to get past this bottom lip that goes up on the font flare putting the, on a regular blazer any adivise?
Old Oct 23, 2012 | 05:51 PM
Other pics
Old Oct 23, 2012 | 06:10 PM
warthogdriver's Avatar
I trimmed that i think....let me look at the how to again to refresh.
Ok....i think i trimmed the fender. Its been awhile since i did it.
Flare trim seemed easier. Go over the how to i did....its in there to give ya an idea.
Now having looked at where you marked your flare trimming the flare wont work at all.
it should line up better then that.
i will post up some pics later tonight when i get home.
thats trimmed fender
Last edited by warthogdriver; Oct 23, 2012 at 07:16 PM. Reason: Figuring things out
Old Oct 23, 2012 | 07:39 PM
So you trimmed your fender and did nothing to your flares?
Old Oct 23, 2012 | 07:43 PM
And the pic I put up was just the flare being held up it was even with the body line it's just that lip that goes up and I'm not sure what to do
Old Oct 23, 2012 | 07:50 PM
i had to slightly shave the bottom lip of the flare (with utility knife) to contour the body lines...i also trimmed the fender to match the curve of the flare....you could leave the fender alone. i think the flare would hide the fender lip at the wheel well. i remember trying to decide to trim or not on the fender.
Old Oct 23, 2012 | 08:16 PM
I'm not sure if I follow what your saying that lip on the flare that goes up in the middle wont allow me to put the flare on all the way
Old Oct 23, 2012 | 09:59 PM
thats the portion i shaved with the utility knife to match the fender.
i then trimmed the fender to match the point where the flare and fender make contact.
shaving the flare to match the fender profile made the two parts align better...i then trimmed the portion of the fender that sits below the line where the flare and fender meet to clean up the look.
in the pics i posted that is where you are having the overlap issue. on a zr2 fender there is an additional lip in the wheel well opening to fit the flare...our fenders dont have that so the flare will be meeting up with the fender, thats why you have to shave the flare to make it flush with the fender surface...then trim (from fender) what is exposed below that line.
https://blazerforum.com/forum/articl...-4-door-57919/
read thru that again...the pics are there for what i did.
Old Oct 23, 2012 | 10:10 PM
So did you just cut the lip off or trim it down
Old Oct 24, 2012 | 06:31 AM
how i trimmed the fender and shaved the flare is in the how to.
