2011.06 ROTM - Verno
Old Jun 13, 2011 | 08:23 AM
Default 2011.06 ROTM - Verno
Congratulations to Tim (Verno) for his win in the June 2011 ROTM with his lifted 2000 ZR2 Blazer!
Pictures:
Mod List:
8" Solid Front Axle Conversion Lift.
Long Arm, 4 Link, Coil Spring, Solid Axle.
2005 TJ Rubicon Dana 44.{Front}
10 Bolt 8.5 {Rear}
ARB Front Locker Compressor.
Detroit Trutrac Rear.
Softride Coil Springs.
Skyjacker Stainless Steel Brake Lines.
Ultimate Quick Disconnect Sway Bar Links.
Lower Control Arm Johnny Joints.
Moog Ball Joints.
Fabtech Long Add A Leafs.
Tenneco Automotive Shocks.
Daystar 1.5 Greasable Shackles.
Custom Front & Rear Driveshafts.
ABS Brake Option (allows S10 Hub and Bearings on the TJ Axle to keep ABS brakes).
New Jeep TJ Rotors Redrilled for GM 5 on 4.75" bolt pattern.
233/231 Tcase wide chain, 6 plantary, fixed output conversion.
Completely Rebuilt 4l60e.
Cknaffle Hidden Winch Mount.{not installed}
Mile Marker PE 8000 Winch.{not installed}
4.56 Motive Gears.
Felpro Intake Gaskets.
K&N Drop in Air Filter.
Mobil 1 Full Synthetic 5-30W.
Royal Purple Max Gear 75-90W Synthetic Fluids Both Axles.
10X15 Series 218 Eagle Alloy Wheels.
35X12.50X15 Superswamper SSR Radials.
Ziebart Rust Protection.
Pioneer Headunit 50X4.
3 Way 4x6" Pioneer Dash Speakers.
3 Way 6 1/2" Pioneer Door Speakers.
4 Way 6X9" Pioneer Rear Speakers.
Fusion Dual 12" Encloser.
Fusion 600 Watt Monoblock Amp.
Chrome Billet Grille Insert.
GTS Deflector.
12" Anntena.
Optima Red Top.
KC Long Range 57 Series 100 W. Lights.
Clear Corners.
Euro Tailights.
Freshly Painted Flares, 'Spectre Gray Met'.
Two Tone Power Leather Seats.
4.3 TomTom GPS Nav.
Beltronics RX65 Radar Detector.
It still gets just a little better than 18mpg highway.
Tim's Profile
Tim's Garage
