Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Fuel consumption
Old Jan 18, 2022 | 08:26 PM
Hess13x's Avatar
My 97 4x4 4 door averages 14.5.
Old Jul 2, 2022 | 03:00 PM
Stovey's Avatar
Stovey will become famous soon enough
Maybe change the PCV valve, and clean the EGR valve and the MAF sensor. These made a noticeable difference for me, and are quick, cheap and easy.
I also noticed improved fuel mileage after replacing the fan clutch assembly.
Old Dec 23, 2024 | 10:16 AM
Cyphercrash's Avatar
Cyphercrash is on a distinguished road
Originally Posted by steveduns
I would perform a fuel pressure leak down test to check for a vacuum leak or other condition that would cause a rich fuel condition. Below is a link to instructions on this site from Captain Hook that has detailed instructions on running the test. If you don't have the tool to perform the test your local parts store will usually let you rent one for free. I'm in the process of troubleshooting the exact same problem on my 2000 ZR2 with no CEL's and engine runs great. Hope this helps.
Fuel Pressure Leak Down Test
Knock sensor(s)?
Old Dec 23, 2024 | 03:01 PM
Originally Posted by Cyphercrash
Knock sensor(s)?
Knock sensors are little microphones that screw into the block. These are monitored for preignition so that the timing can be adjusted by the ECU and prevent damage. They also can adjust the timing so that it can be advanced as much as possible without causing damage to maximize performance.
Old Dec 23, 2024 | 03:21 PM
Yeah they can also mis adjust your air fuel mix making your fuel economy tank
Old Dec 27, 2024 | 04:43 PM
LesMyer's Avatar
This is an incorrect statement. Your inexperience is showing! Christine had it right.
Old Jan 13, 2025 | 06:46 PM
GeorgeLG's Avatar
+1
George
Old Mar 4, 2025 | 03:13 AM
What is the mileage driven on each trip?
The lenght (or the shorteness) of the ride, especially in winter time can considerably lower your mpg.
Short trips <8 miles can increase fuel consumption considerably due to the enrichment at cold engine.
What are the average meteo conditions in the period you observed the low mpg?
Cold below freezing?
The 4.3 V6's are terrible on short haul trips in cold weather.
Old Mar 4, 2025 | 07:18 AM
Stovey's Avatar
Thank-you Error_401, this explains everything.
My engine seems to get about 14 mpg in summer, but in winter it drops significantly. Without my notes, I would say 11 mpg or worse!
This is all city miles and all short trips, about 5 miles. The temperature is below freezing all winter, and averages -20 C or -5 F.
robbyroo1972
Oct 9, 2013 11:46 PM
Dolanjohn1990
Jun 4, 2012 02:11 AM
a_tack
Aug 7, 2008 01:51 PM
00blazerLS
May 6, 2008 03:02 PM
BlazeRDA
Dec 11, 2007 04:54 PM
