HPTuners tune specific discusion
I have the professional version of the tuner and I run it religeously on my vehicle to check and record long drives. Using this of course allows me to make many changes to the computer controlled systems and processes. I have removed ALL of the torque reduction, increased spark dwell time, remapped timing and air/fuel charts. On a stock jimmy with high grade tune up parts and premium fuel. I have gained quite a bit. Much more power is noticed and plowing and towing is even easier. (I have to add traction bars/lift bars to prevent the squat in the back under hard acceleration) The vehicle drives completely different then it did before. I made sure to set the "stock" tune for the tow mode button. That way I can put it to stock again to use the butt dyno and compare my tune to original factory tune.
My ?'s are... Does anybody else have a tune they want to share? tuning tips? do's and don'ts? Its not easy using these tuners so I'm thinking we should start a repository for our vehicles here. This would help others to tune the way they want and help other members. (it cost about 100 to tune a single vehicle) |
*bump*
can you drive with that thing on and see what your air intake temps are and stuff like that i dont have the tuner but i have a custom tuned pcm running my supercharger i was just wondering if you can moniter your engine sensors while driving
| All times are GMT -5. The time now is 09:18 AM. |
